What all do I need to remove inside my 81 to get to the heater core. I have a leaker.
I'm not afraid of the work, I just hesitate when the dash is involved. I have a 81 in really solid shape. Can I get by with just taking the glove box door and liner out?
WOW....when I did mine I had the entire dash out as part of my restoration....but from what I remember...there would not be enough room to remove the cover through the glove box.
I just did mine and I went in from the front engine compartment, no need to remove dash or anything. I will load up some photos if you need to see how its done. PS : I do not have air ,if you do it may be a problem , not sure where air unit is on yours if you have it.
dariopop, I DO have air, so there is quite a large exchanger box in the engine compartment. I'll seek advice from above and give it a shot. Thanks to Brian P for his instructions, this will help!
That's a fun job. I have some pictures when I did my 81...if you want them I can email them to you. I also had an instruction sheet but I don't know where that is at the moment.
