Can you identify
I'm not sure if I forgot or if I ever knew what is in the red circle is and used for. Can someone tell me?
http://www.logiqueinformatique.com/m...ltC5Circle.JPG |
Originally Posted by vette747
(Post 1577391608)
Originally Posted by lucky131969
(Post 1577391744)
It's for mounting the optional (race only) saw blades, that extend past the front of the car. Especially useful when racing through a wooded area.
It looks like one of the grounding points. Could you be more specific of it's location on the car?
looks to have a rubber bushing of some sort under the washer. if thats the case, would make a poor ground. maybe a suport for an option, or somthing that goes on the Z06 and not the base modle, or somthing for the vert.
Originally Posted by Outlawwed Z06
(Post 1577395738)
It's the head of one of the front cradle mounting bolts-the rivet keeps it from turning when you're installing/removing the nut from under the car.
Look around,you'll find 3 more... |
(Post 1577395738)
I've always wondered what they are for as well. The C-6 has the same things too.
Originally Posted by Carcass
(Post 1577400352)
Originally Posted by zeevette
(Post 1577400473)
The rubber bushing does nothing to prevent that from being a ground. Metal is still contacting the metal through the screw.
can you give me one example of a factory ground using a rubber bushing between the washer under the bolthead and the frame it is bolted to? just 1 example will do. |
Like Carcass stated, Its the captured head of the Cradle bolt. If you look directly below the bolt where it exits the cradle, there will be a LARGE nut securing the cradle. There are THREE more of them up front and four in the back just like it.
You can see the NUT in this pic: http://img.photobucket.com/albums/v4...wldrainsII.jpg Heres the GROUND Lugs: http://img.photobucket.com/albums/v4...ephotos009.jpg http://img.photobucket.com/albums/v4...ndG-104002.jpg http://img.photobucket.com/albums/v4...isected016.jpg http://img.photobucket.com/albums/v4...pointG-401.jpg http://img.photobucket.com/albums/v4...dlocations.jpg NOTE! If you ever have to remove a cradle bolt,, DO NOT use an impact wrench. |
Starting to think Bill was on the engineering team for the C5! :thumbs:
No,, SORRY,, but,, I wish I was. I work on a LOT of them and get my hands dirty quite frequently. Being an Ex Submarine Sailor for 26 years sure helps. I enjoy working on them. :D:thumbs:
I Take lots of pictures! BC |
Originally Posted by Bill Curlee
(Post 1577406909)
I Take lots of pictures! BC they tried to get me to do that, declined and did AE for 8. :cheers: |
Thanks a lot for the answers! It also explains why we cannot use an impact rench when we remove craddle bolts because the some part of the body will need to be removed to access the bolt and stop them from turning. And yes we found 4 ou each side when we parted out that C5 over the weekend.
This one is in the front just beside ground G102 close to the head light: http://www.logiqueinformatique.com/misc/front.JPG This one is close to the battery: http://www.logiqueinformatique.com/m...ontbattery.JPG And the two other for the rear bolts: http://www.logiqueinformatique.com/misc/rear cut.JPG |
After seeing that last picture, why do you care what it is for ??
:rofl: |
(Post 1577391744)
Holy Cow man. Hope my ride never looks like that. Interesting pic...
(Post 1577403192)
Orealy?
can you give me one example of a factory ground using a rubber bushing between the washer under the bolthead and the frame it is bolted to? just 1 example will do. Read my post. I didn't say it was a ground. I just said there's metal touching metal, that wouldn't prevent it from being a ground. Yeah, Really. |
