umplug cable please ID
last saturday. I notes a wire cable plug to nothing.
the cable runs from the left side to right side of the engine bay. tied to the bar that is between the radiator and the front of the engine can someone tell me where this cable go. here is a picture of the cable [IMG]http://i1111.photobucket.com/albums/...1-10125509.jpg[/IMG] |
Knock Sensor or Coolant Temp Sensor they are on the left and right of the block near the spark plugs.
Passenger side is about halfway back on the block. Drivers side is about 1/4 way back on the block. |
First, I know by your other threads, your car seems to have all sorts of "custom" wiring :lol:
But to really help, you need to update your profile to show the year of your car or at least state the year of the car in the thread. Not all C4's have the same wiring harnesses as they may have different wires based on the year of the car and possibly certain options. How long is the wire? Where does the wire originate or come out of a protective loom? It looks like the wire is green, right? A pic of the area where the wire originates will help too. This could be a wire to the auxiliary fan (RPO KC4) which was part of the early Z51 or Z52 suspension packages. If the fan isn't there (it will be under the car in front of the A/C condenser) somebody could have removed it and simply relocated the wire. Is there a single wire going to the main fan? Does the main fan work? |
Low coolant sensor in the radiator ??
Originally Posted by JackDidley
(Post 1579224659)
in what part of the rediator this sensor is please advice . I was looking on the right side for a sensor did not see any. |
Originally Posted by c4cruiser
(Post 1579224263)
But to really help, you need to update your profile to show the year of your car or at least state the year of the car in the thread. Not all C4's have the same wiring harnesses as they may have different wires based on the year of the car and possibly certain options. How long is the wire? Where does the wire originate or come out of a protective loom? It looks like the wire is green, right? A pic of the area where the wire originates will help too. This could be a wire to the auxiliary fan (RPO KC4) which was part of the early Z51 or Z52 suspension packages. If the fan isn't there (it will be under the car in front of the A/C condenser) somebody could have removed it and simply relocated the wire. Is there a single wire going to the main fan? Does the main fan work? I just update my profile. you are right. I first open my CF account, before I had my vette. and forget to update. after. the wire is long a go from left side of engine to the right side. I know is have to be plug some where in the radiator right side. or very close to that general area. the radiator fan working ok |
The sensor on my 89 is just under the top radiator hose inlet. Maybe down 2 inches.
Originally Posted by BroCorvette
(Post 1579224258)
Passenger side is about halfway back on the block. Drivers side is about 1/4 way back on the block. My model only came with one fan on the radiator. that sensor you are talking about is for those car that have the 2 fan on the radiator. |
Originally Posted by cadwiz_89
(Post 1579224965)
2 Attachment(s)
(Post 1579224659)
Originally Posted by hitmanpty
(Post 1579224874)
I know it have to be on the radiator. since the wire was neer the right side of the radiator.
(Post 1579225653)
Very possible!
The low coolant sensor will be on the right side of the radiator. These pics are of my 87. Note that the wire on my car is green and the connector is the same as in your pic. |
