2005 roof recall........
I just read in one of the posts here that there was a recall on the 2005 roofs. What was the recall about? I just bought my 2005 about a month ago and I was just wondering about it. Thanks.
the roof skin would delaminate and fly off your car.. i believe they had a recall on them, so my guess yours was probably already fixed..
Have a dealer run your VIN to ensure the recall was performed. Initially, GM issued a Technical Sevice Bulletin to deal with the issue if customers brought in their cars. Totally up to the owner if they felt there was a problem, and went into the dealer on their own.
Then, when the TSB repairs were found not to work properly, GM eventually issued a full recall. The process took quite a while to do, and IIRC, it was only recently (this summer?) completed - that means GM sent out all of the notices, not necessarily that all cars have been completed. |
Bought my '05 in May 2010, took it to the dealer for fluid changes and they told me there were 3 outstanding recalls, one was for the roof, they took care of everything else and ordered a new roof, had to be painted by a local body shop but they did a good job, everything took about a month and went fine, good luck with the new car, I'm sure you'll LOVE it!
My 2005 base, and 2006 ZO6 was part of the recall also. The 2005 roof was foamed. The ZO6 was painted and replaced since it was in the process of delaminating.:cheers:
Originally Posted by RobLo
(Post 1579299968)
The potential roof delamination problem affected more than just the 2005 model and there may have been two roof 'recalls.' I've had 2 roof panels replaced on my 2005 but the first was probably done under a customer satisfaction program...the full-blown recall followed a bit later.
If you need information about TSB's or safety recalls check out this website: http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm |
Originally Posted by Wayne O
(Post 1579301367)
Originally Posted by J Willis
(Post 1579299556)
(Post 1579301367)
