Three beeps
My 2008 Ragtop has started something weird with the horn. When I shut the car off, open the door and close it I get three very sharp and short beeps. Doesn't do it every time, but just about every time. Guys at Chevy don't have a clue and I am out of ideas.
I don't know if it's related or not but the Fuel Mileage as gone to pot too. Was resting at about 32 hwy and now it's hovering around 24 to 25. I have had fluctuations before and the Chevron injection cleaner always cleaned it up. This time it had no effect at all and to top it off I can't see a plug nickels difference between fifth and sixth gear. Anybody got any ideas? |
The 3 beeps is usually a sign the key fob has a low battery, The cars computer thinks the fob is still inside the car (because it cant detect the signal and it wonders how the door opened) so it honks the horn to let you know the key fob is still inside even if its not. (Its trying to prevent you from locking the fob in.)
As for your fuel milage, have you significatly changed your driving habbits, IE more stop and go and less long drives? The computer is always calculating these things and makes adjustments to the average economy readings. lastly you will not see much difference in economy between 5th and 6th gears, since both are overdrives the car only sees a small rpm difference between the two. :thumbs: |
The 3 beeps probably means you're staying too close to the car after you get out and shut the door. The fob antennas inside the car can still detect the fob and the car "thinks" it was left in the car.
Either turn off the "fob left in the car" warning or else move the fob a little farther away from the car a little sooner. It has nothing to do with the fob battery getting low. |
Did you have the "Fob Warning" activated on your DIC? Or sometimes your DIC option settings will simply change themselves for no reason, like any computer. But more often, multiple issues like you are having are related to some electrical problem in the car. Usually, the main car battery is dying. You can have it tested and replace if indicated, but sometimes the tests don't find a bad battery. Try putting a charger on it and see if the problems go away for a couple of days.
Merry Christmas! :cheers: |
I agree with Roger and Jim; The car thinks there's a fob in the car. Mine did that if If I got out and my wife had the other fob in the car. I turned off the fob warning; problem solved.
As for the gas milage; I noticed a 10% drop when ethanal was added to gas and I always get lower milage in the winter if the gas formula is changed here in the Northeast. MERRY CHRISTMAS ! |
:iagree: Happens to be quite common if you have the FOB in your pocket when you start closing the door and you are not completely clear of the door opening.
Originally Posted by JimTN
(Post 1579555062)
Originally Posted by Pat Wells
(Post 1579554929)
I don't know if it's related or not but the Fuel Mileage as gone to pot too. Was resting at about 32 hwy and now it's hovering around 24 to 25. I have had fluctuations before and the Chevron injection cleaner always cleaned it up. This time it had no effect at all and to top it off I can't see a plug nickels difference between fifth and sixth gear. Anybody got any ideas? Just an FYI, you stated your car is a 2008, and factory/original batteries are notorious for lasting about 5 years. Get ready for some weird DIC messages soon and start with the main battery, right Gearhead !:lol: |
Originally Posted by Glen1224
(Post 1579555165)
(Post 1579555062)
My vert does the 3 beeps from time to time if I have the fob in my right pocket. If i have it in my left pocket, it seems to know the fob is not inside the car, and I don't get the 3 beeps.
Different version from Tony Orlando and Dawn ...................... :rofl::hide:
it is the fob reminder, my car never used to do this but for the last couple of years it does it a lot - it can be embarrassing at times because the young girls think that i am honking at them
Oh yeah ........
Originally Posted by Mad*Max
(Post 1579556916)
Uh huh ............. likely story ................. :rofl: |
Originally Posted by MikeyTX
(Post 1579556926)
[/COLOR]
Originally Posted by caroutisine
(Post 1579556797)
The pieces are falling into place. Looking back, the beeps always happened when I went somewhere where I could't carry. I am so use to haveing my .380 in my right pocket that it feels wrong when I have to leave it at home. So, I put the keys in my right pocket when I go to the V.A., post office, or some other Dumb ass government facility where I can't carry my gun. All other times I carry my keys in my left pocket so they don't get hung up in the trigger.
Seems that was it, at least it's worked out the last couple of days. Who would have seen that one coming...... |
I wrestled with the three beep event for a long time until I finally discovered that my FOBs hang on a key hook just inside the house when you step in from the garage. The FOBs were sending the signal to the car from that short distance. I moved the key holder elsewhere in the house and that solved the three beep eventII :thumbs:
