Will stock bottom end take this?
zz9 cam
ported alu heads minram headers ATI procharger at 10psi Or is it a timebomb? |
Re: Will stock bottom end take this? (devilfish)
Is it 10psi with an intercooler? If your getting 10 psi (non-intercooled) at the manifold with other mods it is a time bomb on stock pistons.
Re: Will stock bottom end take this? (dgoodhue)
stock bottom wont be able to handle that charger with all that stuff already on it.
I'm new to the forum too, but what I've learned from other posts is that the stock cast pistons won't even last long even running 8 psi.
I'm looking into getting an ATI intercooled procharger for my stock LT-1 and even with intercooling I'm still only going to run 6psi 7 tops!!! i want my engine to last a good while. |
tick tock, tick tock. Don't even try it. Even intercooled w/lowered compression I wouldn't try it unless you're eventually planning to rebuild anyway.
Jason |
TimeBomb!!!
But, The rest of that stuff SHOULD make it a Bad MoFo!!! |
Re: Will stock bottom end take this? (FoolCrzy)
everything except the boost would be a great stock bottom end combo. with 10psi a bowtie block would be smart, high end crank and rods and a good dished piston like JE, ross, wiseco would also be bright if you want any kind of milage.
Re: Will stock bottom end take this? (gtsyellow)
Your stock bottom end are fine. Most of you guys are forgotten Shalin Ex-93LT1 running stock bottom end made 555rwhp ran mid 10s in 1/4 mile, The setup were 355ci w/forged piston and 12psi intercooled.
Bruce |
Re: Will stock bottom end take this? (Bruce)
Your stock bottom end are fine. Most of you guys are forgotten Shalin Ex-93LT1 running stock bottom end made 555rwhp ran mid 10s in 1/4 mile, The setup were 355ci w/forged piston and 12psi intercooled. Bruce Vic |
BANG ;)
I would be scared to touch the accelerator pedal with that setup.
Re: Will stock bottom end take this? (STL94LT1)
I would be scared to touch the accelerator pedal with that setup. |
Re: Will stock bottom end take this? (mackeyred96)
BANG ;) |
Re: Will stock bottom end take this? (Glock'94)
BANG ;) BOOOOOM! |
Re: Will stock bottom end take this? (WINNER)
Shalin did not have a stock bottom end. it was a purpose built, forged bottom, 355 with 8.5:1CR.
A stock bottom end doesn't have forged pistons. |
Re: (scorp508)
With the power you gain you face will do this :D . You friends will look at your car like this :eek: you will think its :cool: but your engine is actually playing with dynomite using this :smash: . Then sadly you will be doing this :cry because your engine is :boxing a losing battle. So we have to put it to rest "rip" :nopity . Finally, you will be :U From all the money you wasted :D
[Modified by 92LT1Roadster, 8:55 PM 5/12/2002] [Modified by 92LT1Roadster, 8:56 PM 5/12/2002] |
Re: (scorp508)
I have met and talked to Shalin many ocassion. Shalin Ex-93 vette using stock crank and rods. The only thing was forged is the TRW 21cc "D" cup piston and TS1 rings. Also its a 9:1 c/r. If you guy wants more infor, you can contact Chris at Speed-Demon. Because he own Shalin blown vette now. Bruce 93LT1 Conv w/ZF6 Blown D1-SC/N2O 383ci is being build at Agostino |
With the proper quality fuel, fuel supply and correct tuning you can get by. I just would not run it hard on hot days. Most problems are user related not component.
Re: Will stock bottom end take this? (Blown Vette)
The forced induction guys always say to dump the factory pistons if you want to use boost of any kind.
