Fuse panel
Anybody have a pic of the panel for a 1975 vette.
pluse when i put a volt light on a fuse some only light when i touch one side,and some light when each side of the fuse is touch,my tail light,brake light,turn singles are out thank:ack:s |
Here's a typical fuse box-yours may or may not be the same.
http://i243.photobucket.com/albums/f...op/fesebox.jpg Remove each fuse and check that it's good and reinstall or replace. After the fuse is reinstalled make sure that you have power on both ends of the clips. You will have to turn the key on to power up some fuses. See if that helps and post back. |
If the test light only lights on one side of a fuse, that fues is bad.
Fuse
Originally Posted by petes74ttop
(Post 1579726399)
Most owner's manuals have a pic/diagram of the fuse panel.
:thumbs: |
