pre-supercharger install questions
I bought an A&A kit on the forum and will be installing it in a few weeks, but I have a couple of questions. I'll post my setup with questions to follow.
Items I have: 05' ls2 m6 stock c5 z06 diff 3.42 w/ c6 z06 output shafts mcleod rst w/ ls1 flywheel LG 1 7/8 header with catted x pipe modded z06 bi mode exhaust A&A v3 si kit w/ 3.5" pulley single nozzle meth kit A guy I work with has EFI live and has offered to let me use it so I'd just have to buy a credit and take the car to my tuner. I don't see many people in the F/I forum using EFI live, will I run into trouble using it? Would it be better to use HPtuners? I'd like to use a 2 bar map sensor and add an IAT for meth tuning purposes. Will I be able to make this work with either tuning tool? Where or who should I ask to get a good startup map for EFI live so that I can get the car to a dyno. I'm still looking for a crank pin kit or even just the washer/fixture if any body has one they would like to get rid of. |
EFI live is fine. Your car has an IAT you just need to move it post meth nozzle.
A&A told me I shouldn't run anything smaller than a 3.6" pulley because I would be overspinning the blower. You may want to check on your setup with a 3.5" pulley. A 3.5" maybe ok depending on your redline. |
EFI Live will work fine for your setup. I personally prefer EFI Live. If you need any help please feel free to pm me.
Shawn |
Originally Posted by Unreal
(Post 1580136611)
A&A told me I shouldn't run anything smaller than a 3.6" pulley because I would be overspinning the blower. You may want to check on your setup with a 3.5" pulley. A 3.5" maybe ok depending on your redline. 3.8 pulley came with my kit from A&A. 10-lbs of boost is all you need unless you forge the bottom end... Then you might have to increase blower size and crank pulley (overdrive), compression differences...oyoyoye |
(Post 1580136611)
Originally Posted by Tree1985
(Post 1580140890)
:iagree:
3.8 pulley came with my kit from A&A. 10-lbs of boost is all you need unless you forge the bottom end... Then you might have to increase blower size and crank pulley (overdrive), compression differences...oyoyoye Vortech's calculator says that with a stock crank pulley and 6500 rpm redline the blower should spin a bit over 50,000rpm. The V3 si is rated for 52,000 rpm. The person I bought the blower from was running a 3.25" pulley and the blower held up fine, but I'd rather not overspin and that's why I went with the 3.5" pulley. I was also under the impression that the bottom end should be fine if I'm using the water/meth. Correct me if I'm wrong, but I don't imagine that the blower will make more than 14lbs with the 3.5" pulley. This info is based on my research so far and I'm no expert so if I'm out of line here I might have to swap pulley's if the car makes to much boost. I do have the 3.8" pulley from the A&A kit as well. |
Yes the IAT is built into the maf so you need to add another if you want to move it.
14psi on a stock bottom end sounds a bit risky. |
Originally Posted by neveret
(Post 1580136349)
Items I have: 05' ls2 m6 stock c5 z06 diff 3.42 w/ c6 z06 output shafts mcleod rst w/ ls1 flywheel LG 1 7/8 header with catted x pipe modded z06 bi mode exhaust A&A v3 si kit w/ 3.5" pulley single nozzle meth kit A guy I work with has EFI live and has offered to let me use it so I'd just have to buy a credit and take the car to my tuner. I don't see many people in the F/I forum using EFI live, will I run into trouble using it? Would it be better to use HPtuners? I'd like to use a 2 bar map sensor and add an IAT for meth tuning purposes. Will I be able to make this work with either tuning tool? Where or who should I ask to get a good startup map for EFI live so that I can get the car to a dyno. I'm still looking for a crank pin kit or even just the washer/fixture if any body has one they would like to get rid of. You'll be fine with EFI Live. We use HP Tuners so can't help with a base tune for EFI Live.
(Post 1580147138)
:cheers: |
Originally Posted by Frank@AandACorvette
(Post 1580149456)
Congrats on your purchase. If you need any parts, or get hung up on the install give us a call.
You'll be fine with EFI Live. We use HP Tuners so can't help with a base tune for EFI Live. What calculator did you use? When I calculated it I got 48,471. You probably won't get 14 PSi out of a Si with that pulley. Boost will vary depending on your mods. I don't think you'll need to use that 3.8" pulley, but it's good thing you have it just in case. :cheers: I used the calculator on vortech's website. According to them the internal step up is 3.6:1 which is the same as the V2. If you plug in this data - crank pulley 7.5" - shift rpm 6500 - blower pulley 3.48" the calculated impeller speed is 50431.03 rpm. http://www.vortechsuperchargers.com/...d%20Calculator here's the specs on the V3 si for reference: http://www.vortechsuperchargers.com/product.php?p=148 So what kind of boost do you think the blower will make with the 3.5" pulley? Would you consider this setup risky for the bottom end while spraying water/meth? |
I see what happened. I used 7.25" for the crank pulley size.
It's hard to be exact, but I'd say 8-10 PSi. With the water/meth and a good tune it should be OK. Let me know if you need that pin kit. |
