Install of the new 2012 centennial edition steering wheel on a Corvette 2006 z06.
22 Attachment(s)
Hi forum members...
This is my first trial of doing a DIY thread with photos... Please be kind with your remarks regarding spelling or the photo quality... As you already know the 2012 steering wheel need some remodeling due there is no radio buttons on the 2006 model. First start by removing the radio controllpanels from the new steering wheel. These are just fixed with some sticky glue. Remove the radio control buttons under the panels. (Just two screws). Now the fun starts. First I put a layer of epoxy on the backside for stiffness. Attachment 48186717 Attachment 48186718 When its hardened I put some filler on. Attachment 48186719 Attachment 48186720 After 2 layers with some sanding/grinding it look like this. Attachment 48186721 I decide to go with wrapped foiled carbon (similar to Dinoc) to cover it up. Attachment 48186722 Attachment 48186723 Here is the result. Attachment 48186724 Attachment 48186725 Now its time to install the steering wheel in the car. Start with removing the plus cord from the battery. Attachment 48186726 Here is the old SW Attachment 48186727 We start by removing the airbag. Just put a small screwdriver in the small holes and push gently as pictured and it will come off. Attachment 48186728 Remove the connectors (marked with different colors so you cant put it wrong then when you assembly the new SW) Attachment 48186729 Start unscrewing the big central nut, lock the SW with your knees and the just tap firmly one the left and right side of the SW and it will come right of. Attachment 48186730 Now its completely removed.(The splines have a marker 12 0´clock so you cant put the new SW on the wrong angel) Attachment 48186731 Now put the new SW on and tighten the lock nut firmley. Because the are different main connectors on the 2012 SW I dismantle the old one and used this instead. Its real simple to change and are just fitted with a big metal clip in the center of the wheel. Attachment 48186732 Now put all back in reverse order ( No pictures) and here is the finished result. Attachment 48186733 When I was in one move I also put some carbon foile on the center console and the speedo corners to have a symmetric look. This was my first try to wrap and I quiet contempt with the result... Attachment 48186734 Attachment 48186735 Attachment 48186736 Attachment 48186737 Attachment 48186738 As you can see I also changed the knobs (gearshifter and handbrake centennial edition) to match the SW. (Thx kevin@partstaxi.com) I Hope you find this DIY helpful...:thumbs: Just put the pedal to the floor and have a nice day with your Z06.. BR/ Fastashell |
You got some nice wrapping skills.....looks real good! :thumbs: :cheers:
Originally Posted by TapOut
(Post 1580585654)
:cool:
I was going to do this but I am now just going to add radio controls to the car through my aftermarket stereo. Got a new clock spring on the way soon. It will make te controls functional and make controlling the radio much nicer. Win win. Great write up though you did a great job!
that looks :cool: nice job!!
Looks great!!
Good work and write up!
Holy crap..thats a pretty big improvement. Nice write-up too. Thanks!
That looks so much better. :thumbs:
Steering wheel and trim looks awesome. That yellow tach looks out of place IMO. That belongs on a Ferrari.
You got mad skillz!!! Great job! :thumbs:
Nice job.
What was the material you used if it is not 3M Di-Noc? 3M had two versions, 600 that was 8 mils thick and the new version 1080 that is 3.5 mils thick and easier to apply to compound curves. |
Great write up...nice work, you got skills!
Damn man nice job :cheers:
Originally Posted by Random84
(Post 1580585951)
:withstupid:
PS - I gotta agree about the yellow tach. Unless your car is yellow, then it might look kind of okay. |
Genius idea with the center console piece... My tint guy across the street from me does that all day and it never even crossed my mind to wrap that.. Looks like i know what ill be getting done tommorow
Thx for all nice replays...
I bought this wrap from a local dealer and I don't no the fabricate of it, that's why I says i pretty much the same as Dinaoc...
KR/Peter |
Cool beans! :cool:
I was looking at that wheel a short time ago and was wondering how to take care of the button issue. Nice solution! |
