Driver Door Control Module
First my door would not unlock, then my side mirror (driver) would go to wrong position, then windows would act strange. After 2-3 days of this, now nothing works. I cleaned the door lock pads and I removed the door panel. I do not see where the driver door control module would be. Is this under the dash by door?? I found a picture of the passenger control module. It is on the door next the the large subwoofer. I may have a loose connection but don't know where else to look. If I touch the door lock pad, I hear small clicks. I can lock and unlock my car with my fob. The car starts and drives well except for this issue.
If anyone knows or has suggestions, I would be deeply appreciative. I might even get choked up. :-) Thanks! |
1 Attachment(s)
The module is in the door at about the same location as the passenger door module is located in the other door.
Bill |
Would you happen to know what the part # is?
I don't see anything on the door itself. Would this be the piece that is on the door panel where the windows and door buttons are located?? |
It isn't the black module that is a part of the Window Regulator is it? There is a large bundle of wires that connects to that piece.
1 Attachment(s)
The picture shows it very close to the window switch. It does have a lot of wires going to it. The Master Component List indicates it is: Behind the driver door trim panel, bottom center of the door, rear of the speaker .
Here is the connector end view of the module. Bill |
That connector looks just like the connector on the Widow Regulator. Can anyone verify? Looking at the picture, it does't just show the door. You see the push button to open door, you see the window regulator and everything in between. It is like a picture of layers.
Did you ever get this solved? Having the same issues. Passenger side - No window or door open from the inside out outside.
Window works from driver side and mirror is adjustable. |
Did you ever get this solved? Having the same issues.I had an issue with opening my driver side door today from the inside. I am only able to open the door using the emergency door opener. From the outside, i am able to open the door and can hear the door disengage. On the inside, the window rolls down slightly but i do not hear the door disengage nor does it open.I can hear a bcm relay energizing when I activate the interior door switch . Everything works fine on the passenger side. Can anyone help me with this issue?I did replace new inside door push button
1 Attachment(s)
I have the diaqram.
