C6 Vert Stereo Issue
I have a 2005 Vert with the Bose Nav that links to the HUD. Recently, the single CD player is giving me a message that "No CD is loaded" when there is one loaded. I can eject the disk and get it to work, but I sense this is going to be a problem. I am guessing that this will require replacing the HU which will probably be expensive (no idea how much).
I would really like to put in a better sound system and replace the stock unit (perhaps the Pioneer). I put in the Kicker speaker upgrades from Double D Mods a while back. However, I could be convinced to upgrade those (although they sound good). A more powerful amp would also be nice, but I don't want to do a bunch of cutting and custom enclosures. I don't care if it integrates into the Nav, because I only use it in track mode. I've done some searches, but don't see any clear suggestions. What might be some good options and general cost estimates. I don't mind spending some cash, but don't want to get too outrageous. Thanks for your comments. |
You will get more and better answers here
Thanks!
My suggestion is that you look at a remanufactured 2011 model Kenwood 9980. It is less than half the price of a 2012 model, and has more features. I put one in my wife's car and pocketed the over $700 savings. I think you could get it for about $750 with harness and adapters.
IMHO, spending all the extra $ for the 2012 model is a waste. Kenwood removed a few features on the 2012, and the main new feature, data bus integration, is vaporware, and scuttle butt is that even when it is ready, it will not work with the HUD which is the main reason to have it IMHO. http://i219.photobucket.com/albums/c...6/IMG_0244.jpg |
A basic aftermarket setup would be a component set in the doors and a sub in the trunk.
6.5" components for $150-300 Fiberglass sub box with sub is about $400 Bridgeable 4-channel amp (fronts on ch1&2, ch3&4 combined to power sub) anywhere from $200-600 depending on size, class, brand... Another $50 in misc wires Not including radio $800 can sound pretty darn good, $1400 can be amazing :thumbs: If you want to add (or keep your current) rears, you can power them off of the new HU internal amp, or make the new amp a 5-channel and give them more power. However, in a well powered aftermarket setup the rears aren't needed, and many think it sounds better without them. |
