79 radio wiring
Hello,
A prior owner cut the radio harness off that connected to the original factory radio in my 79. I want to install a new stereo but I am unsure which wires I located under the dash were attached to that original harness/radio. Does any one have a picture of a 1979 radio with its wiring or what color wires connect to the radio? Thanks |
my manual, 68-82 shows (for later models BASE):
yellow: hot to radio fuse 10amp(just when key is on) gray: hot at all times with a 7.5 amp fuse left front speaker tan and gray wires right front speaker: light green and dark green system with REAR speakers gray and yellow same as above brown: light switch orange: goes to ctsy/clk on fuse block 20amp front speakers:same as above right rear: dark blue and light blue left rear: yellow and brown manual does not differentiate between positive and negative for speaker connections |
Originally Posted by Doug1
(Post 1582085643)
Originally Posted by dbartol1
(Post 1582087617)
Thank you. question-Brown goes to light switch? What light? Whats that mean?
Good point.
Is there anyway to look up where on the fuse block the gray wire gets pwr from the 7.5 fuse. Mine has a gray wire but no 7.5 anywhere
On the new stereos what PWR do they use for keeping clock current ahd radio presets?
