79 radio wiring
79 radio wiring
Hello,
A prior owner cut the radio harness off that connected to the original factory radio in my 79. I want to install a new stereo but I am unsure which wires I located under the dash were attached to that original harness/radio. Does any one have a picture of a 1979 radio with its wiring or what color wires connect to the radio?
my manual, 68-82 shows (for later models BASE):
yellow: hot to radio fuse 10amp(just when key is on)
gray: hot at all times with a 7.5 amp fuse
left front speaker tan and gray wires
right front speaker: light green and dark green
system with REAR speakers
gray and yellow same as above
brown: light switch
orange: goes to ctsy/clk on fuse block 20amp
front speakers:same as above
right rear: dark blue and light blue
left rear: yellow and brown
manual does not differentiate between positive and negative for speaker connections
brown: light switch
brown: light switch
brown: light switch
i assume its when the headlights in car go on, the radio will light up for easy night time visibility. remember, these were the stereos from the old days, unlike the new one's that are always lit up
