ZR1 brakes for a C6 Z06
what are your thoughts or experiences with doing ZR1 brakes on a Z06.
Who sells these at a decent price. |
Forum member RichieRichZ06 has helped some folks here get them: http://forums.corvetteforum.com/memb...ierichz06.html
or you could try parts taxi - they have some of the lowest prices another good option would be gm parts house pricing is around 8k for everything usign the gray powdercoated calipers. The other colored calipers cost significantly more. Personally Id buy the cheapest and then have them coated with zinc to look like brembos used on many of the GT1 cars (aside from look ing cool this also prevents the issues that powdercoated calipers face with changing colors after hard use ie red turning brown). http://cdn.speedhunters.com/wp-conte...043_0mHL_3.jpg http://www.speedhunters.com/2009/12/..._gt1_r35_gt_r/ another image from jalopnik http://cache.jalopnik.com/assets/ima...esta09-112.jpg I believe supervettes sells a kit with the calipers and iron rotors for 5k Some go with iron rotors because the cost of replacing the carbon is so high. However the carbon rotors are supposed to have a longer lifespan. Hawk makes pads for the ZR1/Z07 calipers that are made to work for people who convert to iron rotors Hope this helps! :cheers: |
Racing calipers are usually hard anodized, which limits the colors and most are some shade of grey.
the zinc coatings are limited to:
flat gold/bronze, chrome, black, and dark gray as above (my favorite :D) :cheers: http://www.racetechnologies.com/imag...rr_fr-view.jpg http://www.racetechnologies.com/imag...per-forged.jpg http://www.racetechnologies.com/imag...r_top-view.jpg images from http://www.racetechnologies.com/ |
My point being that a zinc paint or coating is not going to hold up- hard anodization is an aluminum oxide layer that is a surface treatment- it's not going to come off and it's about the most durable finish you can do for an aluminum caliper- that's why it's used in a lot of military applications.
The ZR-1 brake setup will run a tad over $10k- for that kind of money, for track use, you might want to consider running an AP, Alcon or Brembo motorsport setup. The AP setup that Essex/Hardbar is selling looks like a very nice setup and is compatible with the Z06 rotors. It depends on why you're looking to upgrade. |
I hate the squeeking of my Race pads, and experencing fade at some tracks....
Originally Posted by CanadianVetster
(Post 1582855692)
I had a Z06 prior to the ZR1, the brakes are worth every penny not just for the performance but safety too....no fade, no boiling brake fluid. My only gripe is the cost of front and rear pads are upwards of $800
I have 7,000 track miles on mine now and rotors are showing virtually no sign of wear. (4 sets of pads though) Pads are easy to change but you won't have connections for electronic wear sensors so keep a close eye on pad wear. One rotor is upwards of $1,200 and there is NO turning or machining them :) One other thing to consider is that unless you run a Sport Cup or R compound tire, the brakes far exceed the traction of the tires so the investment wouldn't be worth it without a tire upgrade. |
Like el es tu says, around $8,000 for the brake setup from a forum vendor like RichieRichZ06.
Do you have wheels that will fit over them, like the ZR1 19/20 inch wheels??:confused2: If not, you'll spend another couple grand on wheels, and maybe that much on tires. So.....$8,000 if you have wheels and suitable tires (like isnider mentioned). Or.....more like $12,000 plus if you also need wheels and tires. Butt....they are fantastic brakes!!!:thumbs: Bob :flag: |
Do the carbon brake not fade at all on track? What are they like under spirited road driving? Do they offer as much feel as iron rotors?
My take on this issue:
The carbon-ceramic rotors supposedly last the lifetime of the car unless the car is tracked. When you track it, the carbon-ceramic rotors inevitably overheat (even though they don't fade), causing evaporation, which weakens the rotor, so you end up having to replace rotors once every few pad changes, not to mention increased damage to wheel hubs, etc. due to excessive heat. Considering the cost of $1250 PER rotor, this is no trivial service. In short, it is not cost effective at all. Where they shine, in my opinion, is that they can be used in stock form both at the track and the street without having to suffer from noisy race brakes :-) Decent racing pads on C6Z06 brakes provide the similar stopping power. Coleman 2-piece rotors save 30 lbs of un-sprung weight overall, making the overall system substantially lighter than even ZR1's. The Coleman replacement rings sell for about $300, so it is much cheaper to replace, too. BBKs are usually better constructed than the stock calipers, and provide space for much thicker pads, which makes them even cheaper to use than the stock brakes in the long run, while providing better brake feel than stock brakes due to less flex under stress. My recommendation: I'd stick to OEM calipers and use lightweight 2-piece rotors with decent, rotor friendly pads like Raybestos ST47/ST43. |
Originally Posted by Ozer
(Post 1582861024)
The carbon-ceramic rotors supposedly last the lifetime of the car unless the car is tracked. When you track it, the carbon-ceramic rotors inevitably overheat (even though they don't fade), causing evaporation, which weakens the rotor, so you end up having to replace rotors once every few pad changes, not to mention increased damage to wheel hubs, etc. due to excessive heat. Considering the cost of $1250 PER rotor, this is no trivial service. In short, it is not cost effective at all. Where they shine, in my opinion, is that they can be used in stock form both at the track and the street without having to suffer from noisy race brakes :-) Decent racing pads on C6Z06 brakes provide the similar stopping power. Coleman 2-piece rotors save 30 lbs of un-sprung weight overall, making the overall system substantially lighter than even ZR1's. The Coleman replacement rings sell for about $300, so it is much cheaper to replace, too. BBKs are usually better constructed than the stock calipers, and provide space for much thicker pads, which makes them even cheaper to use than the stock brakes in the long run, while providing better brake feel than stock brakes due to less flex under stress. My recommendation: I'd stick to OEM calipers and use lightweight 2-piece rotors with decent, rotor friendly pads like Raybestos ST47/ST43. Ian |
Last a life time? No just ask Ferrari Challenge owners with CarbonCeramic race rotors.
about 1/2 a season or 6 race weekends, if that. doing HPDEs or track days is different. |
Hey Andrew. I know you have those ZR1 wheels for the street, but are you planning on buying anothe set for the track?
I'd have to agree with several of the posts above since I know you'll be at the track alot. Upgrade to a BBK because you'll have more options for track wheels and overall it will end up costing you thousands less. Here is a link to a thread with sub links about the whole ZR1 brakes on a Z06. Greg http://forums.corvetteforum.com/c6-z...on-my-z06.html |
(Post 1582855692)
If you can afford the ZR1 brakes and afford the rotor replacements then it would be a quiet option with better track reliability than stock. However its important to keep in mind that the ZR1 brakes are still street brakes and will have the issues that require more servicing when run hard. As far as the noise goes - how long have you been running racing pads on the street? IMO after a while youll get used to the brake squeal - it tells you the brakes are working :D |
What race pad are you using now?
Originally Posted by isnider
(Post 1582861148)
.....Also not necessary to run $75 brake fluid or constant brake bleeding.....
Ian IMHO, you'll need to flush a good high temp racing brake fluid into you brake system if you'll be running the carbon ceramic brakes on the track. You don't necessarily need Castrol SRF, but you'd better put something like Motul RBF 600 or such in there or you're going to have problems. My ZR1 only sees the street, but there was a ZR1 parked next to my C6 Z06 (with stock brakes) in the garages at an event at Daytona a little more than a year ago. I came in from a session and saw he was packing up to leave. I asked what the problem was, and he said his brake pedal was going to the floor - classic indication of fluid boiling. I asked what fluid he was running and he said it was the stock DOT 3 stuff. So....I'd recommend a good DOT 4 racing fluid - those carbon ceramic rotors get hot and will heat up the calipers just like cast iron rotors do. And take care of your fluid by flushing/bleeding just as you would with a regular brake system. Bob :flag: |
Originally Posted by el es tu
(Post 1582862024)
If you havent gotten one yet, you might want to buy a proper brake duct setup and good brake fluid (that you change out regularly). As the others have mentioned, well ventilated floating rotors and separate street/track pads would also benefit you. This is the cheapest way to go in order to get quiet braking on the street and reduced fade at the track. Also you may want to look up the maximum temperature limits of the pads you are running - some street/track pads overheat much faster than track only pads.
If you can afford the ZR1 brakes and afford the rotor replacements then it would be a quiet option with better track reliability than stock. However its important to keep in mind that the ZR1 brakes are still street brakes and will have the issues that require more servicing when run hard. As far as the noise goes - how long have you been running racing pads on the street? IMO after a while youll get used to the brake squeal - it tells you the brakes are working :D AP racing 6 pot calipers http://www.apracing.com/products/rac.../gt_range.aspx AP Racing Ferrari 355 1994on Big Brake Kit 6 Pot ~ http://www.motorsport-tools.com/ap-r...-p-252584.html 2400 Pound Sterling for the front pair |
what would be the point of running ZR1 calipers with Iron discs?????????? The entire point is the weight and heat capacity of the ceramic??!!
I'd never suggest spending the money for an Ceramic kit unless you just want the eye candy....Stoptech (and others) offer amazing brake kits at a fraction of the cost if you want a performance upgrade |
Originally Posted by davidfarmer
(Post 1582862537)
I'd never suggest spending the money for an Ceramic kit unless you just want the eye candy....Stoptech (and others) offer amazing brake kits at a fraction of the cost if you want a performance upgrade Yep Stop tech's trophy kit is right there in pricing with the ZR1 brakes http://www.lgmotorsports.com/product...oducts_id=2097 http://www.lgmotorsports.com/images/STR-1%20WEB.jpg For that kind of money Id just get gary from hardbar to set up something like everett has on his mosler:smiliedrool: http://forums.corvetteforum.com/auto...e-project.html http://i46.tinypic.com/vr5z47.jpg :cheers: |
