Man the transaxles in the C6s are junk! Shifts worse than a dump truck!
I had a Grand Sport and I didn't like the trans; I now have a Z06 Carbon Edition and it is just as junky as the GS. I had a Porsche 930 4spd in my V8 914 race car for awhile and I would say it shifted like an old dump truck it was so notchy, or like an old farm truck from the 60s or 70s.
Well, I never missed gears with it! The C6 trans is a complete POS. Went to the track today with the new to me Carbon and I missed 2nd to 3rd a number of times, it would get hung up in-between what I would guess was first and third, or jump to 5th, so forth. I have to admit I would not have thought a 2011 Corvette would shift worse than a box in a Porsche from the 70s but I have been proven wrong. And I don't force the shifts or grab hold of shifter; I push with my palm and pull with fingers cupped just like any other car/transmission I have ever tracked/driven. I have a short throw shifter that came with an 08 torque tube I picked up for my Nova project so I am going to try that next but I seriously doubt it will make it better, heck, might exacerbate the issue for all I know. When it would shift, the car was fast, even on the stock run flats :rock: You guys tracking these have any fluid brand changes or other things you have done to get this thing to shift better? |
Mine shifts very nicely. You have to shift it properly. Coming from a 4 speed you have to forget most of what you learned about shifting. Only thing that is the same is the 1-2 shift. Put your hand on top of the shifter when shifting from 2nd to 3rd and then shove forward with the heel of your hand the transmission centering spring will take it right into 3rd. Trying to aim it or force it like you would do a 4 speed will guarantee a missed shift. Most tracks you only need to use 3rd and 4th once out of the pits. Sometimes 5th is used on very long straights.
Once you get used to the shifting you should be able to rest your hand on top of the shifter and mover through all 6th gears rapidly just by using your fingers and the heel of your hand. Be careful on a rapid shift into 5th from 4th because the reverse gate is right there and the lock out solenoid is designed to be over ridden if enough force is used. That is done so you don't get stranded without reverse if the solenoid fails in the lockout position. Bill |
Did you buy it used? If so, I would check to see if someone installed a different shifter and then put the stock one back before they sold it. Maybe they didn't put it back right??
I have a 2011 Z06 and any on track shifting issues I have had were my own fault, I couldn't blame any of them on the car. |
Sell it and buy another Porsche and then when the Z06's and GS's blow past you you can flip them off and then do another super smooth shift as they drive away..........
Sorry, just really tired of ex-Porsche folks whining about Corvette trash..... Why did you buy a Vette anyway? Maybe there is something about it that doesn't remind you of a 50-60's dump truck.... Geez |
I really liked the mgw shifter I had on my c6. I rarely have any problems but I've noticed that non Vette owners that have tracked my car had initial problems. Get an mgw and more seat time and enjoy.
(Post 1584215187)
Transaxle?? I think you are in the wrong forum.
how many dump trucks have you driven? :rofl:
Mine shifts very nicely. You have to shift it properly. Coming from a 4 speed you have to forget most of what you learned about shifting. Only thing that is the same is the 1-2 shift. Put your hand on top of the shifter when shifting from 2nd to 3rd and then shove forward with the heel of your hand the transmission centering spring will take it right into 3rd. Trying to aim it or force it like you would do a 4 speed will guarantee a missed shift. Most tracks you only need to use 3rd and 4th once out of the pits. Sometimes 5th is used on very long straights. Once you get used to the shifting you should be able to rest your hand on top of the shifter and mover through all 6th gears rapidly just by using your fingers and the heel of your hand. Be careful on a rapid shift into 5th from 4th because the reverse gate is right there and the lock out solenoid is designed to be over ridden if enough force is used. That is done so you don't get stranded without reverse if the solenoid fails in the lockout position. Bill :iagree: if you just push it forward when shifting into third you will never miss it....if you are trying to guid it into place you will have trouble. Also you need to refresh your clutch fluid quite often. As soon as it starts to look dirty it will start impacting your shifting. The car is stock and really low miles and I know the original owner didn't mess with the shifter, so that wouldn't be it. It had only 989 miles on it when I bought it last month and at 1800 miles now so maybe it just needs to break in more. My GS had 6800 miles when I sold it and I don't recall if it got better or not, I don't recall thinking it was ever really fast shifting 2-3. For some of the other comments... when you have a transmission and diff together in one package it is called a transaxle. I didn't invent that term. Maybe you are on the wrong forum. I suggest checking out Food Channel. As for the Porsche comment, I see crap like your post on this forum all of the time which is sad. You don't know me. I compared it to my Porsche because I had one and ran more than a few transaxles in that car as I increased power and never had shift issues, neither 4 nor 5 spds, like this car. Nor my Mustangs. Nor any other manual transmission car I have owned and/or tracked. I didn't say Porsches are better or anything deserving your lame comment. Plug it. |
I'm knocking on wood as I type this, but in 48,000 I've never missed a shift. This is my 11th Vette and I am very accustomed to how they shift. Make sure your shifter and tranny are ok. C6 Vettes have a pretty good oem shifter. First Vette I've owned that I didn't change it for something more precise.
I've had 3 mustangs, an m3, s4, mazdaspeed6, mini cooper, golf, corolla, and my c6 is by far my favorite. Sounds like there is something wrong with your car or you need to learn how to drive.
Originally Posted by Lawdogg
(Post 1584216817)
The car does scoot otherwise. I was editing video here tonight from today and best lap was a 2:03.2 and my Porsche V8 914 race car was consistent 1:55s, so only 8 seconds off with similar HP but no slicks and a heavier car. I think with slicks and another 100 BHP with some engine parts and a tune I could get this car down to 1:55s. Our local SCCA champion (in a number of classes including T1 in a Grand Sport) that owns a racing school was out with a student today and drove his ZR1 out. He didn't track it today but said with his Hoosier 315s and 345s on Forgelines and a tune to 700HP he has ran a 1:53 which is hauling. That time was my fastest lap ever in my 914 and that car was pretty nuts :cheers: Not that a 700HP ZR1 isn't a bit nuts of course. |
Do not install a short throw shifter. The internet has brain washed everyone thinking they are an improvement. Making the throws long would be an improvement. As for the shifting problem, I think it may be an actual problem. I have yet to drive any manual transmission, in good working order, that was as bad as you described. FWIW, a dog box transmission, like a jerico, sounds clunky and shifts poorly at low rpm, but take it on a road course and use it properly and it will possibly be the best shifting transmission you have ever rowed.
Originally Posted by CyberGS
(Post 1584216725)
.....when you have a transmission and diff together in one package it is called a transaxle. I didn't invent that term. Maybe you are on the wrong forum. I suggest checking out Food Channel.
Originally Posted by jbondfl
(Post 1584215267)
Originally Posted by trackboss
(Post 1584217986)
You may have a clutch hydraulics issue - that fluid can be boiled and deteriorate, especially if you have headers. I recommend a remote clutch bleeder or Tick adjustable master cylinder. Factory clutch hydraulics are weak.
I too occasionally get stuck between 1-3 when shifting from 2-3, haven't figured out why yet. I'm usually not shifting too terribly quick.
(Post 1584217986)
MGW makes a very nice shifter with a "tall handle" option so you get more precise shifts with a slightly shorter throw while keeping the shift knob up near OEM height and close to the steering wheel. |
(Post 1584215267)
