1966 Corvette 327/300 fuel pump replacement
I have factory air and having difficult time getting old fuel pump off. I have removed passenger front tire, lower radiator hose, fuel filter and loosened A/C compressor. I finally got the front bolt off the fuel pump and having hard time getting to the back bolt due to A/C. I'm sure I will eventually get it, but not sure I'll ever get the new one back on. Any suggestions? Any secrets to ensuring pump lever is below push rod?
Also, Ecklers has a GM replacement, but do you know if fuel connections coming in and going out will be the same? |
Are you trying to access the bolt through the opening in the fenderwell?
That's how I accessed the bolts when I replaced the pump on my 65 a/c small block. As for the push rod, are you using a long bolt through the front of the block to hold the push rod on place? |
Originally Posted by 62Jeff
(Post 1584341002)
Originally Posted by Gmont
(Post 1584344801)
I will checkout the fender well opening. Thx
