Air Bag, Steering Wheel, Clock Spring, & Lock Plate Removal PICS -Turn Signal Fixed!
Since my right turn signal did not work, I thought I had a broken wiper switch but after disassembly, I found a much simpler issue: My air bag wire was preventing my right turn switch from 'switching'. When I assembled the clock spring, I fed the wire to the left side out of the way and now I have both turn signals! Since I was going to post pics of replacing the wiper switch but didn't have to go that far. I still wanted to post my pictures & findings in case this helps someone else.
This is on a 91 Corvette Coupe 1) Disconnect negative battery terminal 2) Remove the air bag, 2 torx screws in back, T-30 size. http://i883.photobucket.com/albums/a...ps3f0d6ec5.jpg Unplug air bag & set aside http://i883.photobucket.com/albums/a...ps1084adc4.jpg 3) Loosen 21mm / 13/16" nut holding steering wheel on. Use a puller to remove wheel, or in my case, it came off fairly easily with just a tug. Don't forget where things go.. http://i883.photobucket.com/albums/a...psefce5aaa.jpg 4) Remove nut and steering wheel, feeding air bag wire through wheel hole. http://i883.photobucket.com/albums/a...psa391f6e5.jpg 5) Remove small snap ring holding clock spring on. http://i883.photobucket.com/albums/a...ps2aa2a27b.jpg 6) Gently pull clock spring out. http://i883.photobucket.com/albums/a...ps866c0075.jpg 7) Now you will need a steering wheel lock plate tool. I bought the 70mm one. $14.99 Advance Auto Parts http://i883.photobucket.com/albums/a...ps38a931f2.jpg Attach it to the hub & lock plate and twist the wing nut so you can remove the c-clip holding the lock plate on. http://i883.photobucket.com/albums/a...psb2747913.jpg 8) Remove c-clip. I found it easier to use 2 small flat head screwdrivers and just work it around from one side. Once it's off, relieve pressure on lock plate tool and remove tool, clip, & lock plate. http://i883.photobucket.com/albums/a...psc023cb70.jpg This is behind the lock plate. http://i883.photobucket.com/albums/a...ps75712aed.jpg This is as far as I had to go. It took me about 10 minutes to figure out why it magically started working. Here was the problem: Air bag wire was in the way (wire on left side of pic). Careful when re-installing clock spring.. Hope this helps someone else! To replace the wiper or turn signal switch wouldn't be too many more steps. http://i883.photobucket.com/albums/a...ps57ee1c46.jpg |
:thumbs: Excellent post.
Great write up :thumbs:
Thanks for taking the time to share this. |
Thanks for the great pics.
