help, ecs blower drain plug came off
Anyone know the size and would it hurt the blower to run motor oil in it to get me home, 32 miles?
Originally Posted by danieloneil01
(Post 1587134169)
I would run light weight synthetic in it, such as synchromesh from Mobil 1, Royal Purple or Penzoil to get home. I've seen people run 20/50 in it. Put whatever you can in it to get you home and you'll be fine. |
Thanks blue.
How do you loose a drain plug?? :confused2:
I agree - get what you can in it and drive it home! :thumbs:
Keep us posted on your repair! Thanks,Matt |
Got a fitting from Lowes and put it on with a plug then added motor oil. I used the work truck to get it and not my car. Drove home and the blower sounded normal. Never went into boost either. Plan on draining it tomorrow and adding my blower fluid in. I had to use a coat hanger with some gauge paste (used for finding product level in a tank by handline) because I could not for the life of me see exactly where the mark was on the blower dip stick. Yes, it only takes 4 oz but I like to verify regardless.
Originally Posted by a/c man
(Post 1587136031)
(Post 1587141027)
Hose hitting the ground long enough to back out the plug. I have since zip tied it :)
