LS6 Stock Valve Spring Replacement
What is the current hot ticket for replacing the stock valve springs on the LS6? I have some work coming up and I figured I'd do the springs and trunions "while I'm in there". I don't expect to change the cam now or in the future and the engine has no mods with none planned.
My preference would be for a) Comp Cams parts as they've been my primary cam vendor for a really long time and b) real-world experience vs. "I saw these in the catalog and they look great!". Thanks! |
Originally Posted by billla
(Post 1587329505)
if you don't plan to change the cam, there is no reason, at all, in any way, to spend more than $65 on a new set of GM springs and $40 on new valve seals
i'll be putting ls2 yellow springs in my motor this sunday.
new stock GM LS6 blue springs #12499224 ~$60 is all you need
Originally Posted by mrr23
(Post 1587331278)
all the new ones since at least 2006-2007 are blue would not install yellows, those were the most problematic of all the springs |
The best spring to get is the ls9 springs which are direct replacements for ls6 springs. $80 from lingerfelter. They are also rated at .580 lift
Originally Posted by racebum
(Post 1587332989)
if they are indeed yellow you have new old stock
(Post 1587337038)
What was so problematic about them?
overwhelming majority of broken springs were the yellows new set of ls2/ls6/ls3 blues is $65 from good dealers like scoggin dickey, don't chance it |
(Post 1587337515)
check the valve spring failure thread
Thanks, folks - looks like the GM replacement springs are the right choice for me.
(Post 1587330689)
Thanks! |
(Post 1587337555)
from what I read it was the 02 to 03 years with issues. Gm had redesigned them after that.
it's possible to order ls6 springs individually but it also would increase your odds of drawing on new old stock. i actually received a clutch switch from 1999 when i replaced mine. some of the c5 parts sold via dealer are from the production run |
(Post 1587342314)
P/N for the valve seals? Thanks! 12482063 set of 8 intake valve seals 12482062 set of 8 exhaust valve seals 12637683 valve cover gasket x2 you may not need the VC gaskets |
(Post 1587343558)
12499224 set of 16 GM valve springs
