help! driver door control module
My driver door controls arent working. They worked a few days ago but have since then stopped. I thought it might be the fuse but the fuse is good. They connection pieces were clean. Am I dealing with a short some where? whats the best way to test it? How often does something like this go out? Doesnt look like water could have gotten in there.
Any suggestion would be great! :yesnod: |
I have worked on a number of door issues. There are 2 fuses for the door. Check both of them.
Not at home with my info now. What connections did you check? Also: http://i1250.photobucket.com/albums/...lYourCodes.jpg |
I checked the fuse box on the passenger side. I checked all them but made sure to for sure check i believe 30-34 which is the door fuses. I pulled the codes with my obp II scanner (i think thats the name) and nothing came up. I just check the connection plug from the door to the module. Seemed everything on the connector was in tack no loose wires and they were connected, although I didnt check the electricity current. (as thats where my knowledge stops haha)
To enter the Diagnostic Display function perform the following steps:
1. Turn ON the ignition switch, with the engine OFF. 2. Press the RESET button to acknowledge any warning messages present. 3. Press the OPTIONS button on the Driver Information Center (DIC) and hold. 4. While holding the OPTIONS button press the FUEL button 4 times within a 5 second period. 5. System will first enter automatic display mode followed by the manual display mode. |
Are any of the controls working?
oh didnt know they didnt pull the dash codes. yeah Ill pull the codes and post them. and none of the controls are working..
after reseting the codes and then unplugging my battery I got codes
U1160 B0441 B2605 |
So I checked the fuses visually they looked good. I checked it with an Ohm meter at 20m and all of them were about 1.6-1.8. I checked the measurement of pretty much all the fuses and they all measured about the same. Again electricity is new to me so I'm learning on the fly! So any advice at what Im looking at would be great
Originally Posted by wagner262
(Post 1587455989)
We'll maybe revisit the connector later since you did not disconnect it to look for any bad pins. We'll probably be going into the door later. In the interim you need to get a Multimeter and go on YouTube and learn how to read voltages and resistance. |
My driver door panel went out and then I got Reduced Power on my DIC. Turned out to be a bad driver door harness.
Originally Posted by dadaroo
(Post 1587461156)
Ok, thanks. Your scanner will not pull anything related to the this since it is for engine codes. You can pull all the C5 codes from the dash. Try this: Retreiving & Clearing Codes on a 1997-2004 C5 Corvette - YouTube We'll maybe revisit the connector later since you did not disconnect it to look for any bad pins. We'll probably be going into the door later. In the interim you need to get a Multimeter and go on YouTube and learn how to read voltages and resistance. |
found the short. It was in the door. all fixed! thanks guys
(Post 1587465835)
not a solid connection
(Post 1587467391)
Glad you found it. |
