1986 HVAC C68 dead blower motor
Hi,
I have an 1986 with the C86 electronic A/C. My blower motor will not run at all. Current conditions/findings: - I can directly connect the blower to the battery and it will work fine - The single fuse next to the blower is good - There is a 2 wire and 4 wire connector that plugs into the A/C condenser box: - On the 2 wire connector, the red wire has 12 volts, with the HVAC fan on 10(measured between the red wire and the engine block) - On the 2 wire connector, the green wire does not show continuity to ground, but I cannot find where it comes out of the wiring loom to test continuity of the wire itself. Thanks for any help. |
Originally Posted by Square
(Post 1587508234)
Hi,
I have an 1986 with the C86 electronic A/C. My blower motor will not run at all. Current conditions/findings: - I can directly connect the blower to the battery and it will work fine - The single fuse next to the blower is good - There is a 2 wire and 4 wire connector that plugs into the A/C condenser box: - On the 2 wire connector, the red wire has 12 volts, with the HVAC fan on 10(measured between the red wire and the engine block) - On the 2 wire connector, the green wire does not show continuity to ground, but I cannot find where it comes out of the wiring loom to test continuity of the wire itself. Thanks for any help. On the 4 wire connector. Black is ground. Black/Red is the output voltage to the Blower Motor. Brown wire is the variable voltage from the HVAC Control Head. At Blower Speed 10, you should measure over 6 volts on the Brown wire. As you decrease the blower speed the volts should drop on the Brown wire. If no voltage on the Brown wire, the HVAC Control Head is bad. If there is no voltage coming out of the module on the Black/Red wire, the Blower Control Module is bad. http://i135.photobucket.com/albums/q...ps922d7047.png |
Thank you very much!
When I do the measuring, can this be done with the 2 and 4 wire plugs disconnected, or do I need to back probe the wires to get them to read correctly?
Originally Posted by Hooked on Vettes
(Post 1587509916)
The Red wire powers the Blower Control Module and should be battery voltage.
(Post 1587510478)
When I do the measuring, can this be done with the 2 and 4 wire plugs disconnected, or do I need to back probe the wires to get them to read correctly? Stick red probe on brown wire. Black probe on Black wire. Turn ignition On. Select Auto mode. Manually vary the fan speed. You should see a changing DC voltage around 2-7 volts depending on the speed selected. Zero volts on the Brown wire when Off. If that works you should see a varying voltage on the Black/Red wire which goes to the Blower Motor. |
Here is what I found:
https://cimg2.ibsrv.net/gimg/www.cor...6ab46dc6ef.jpg On the 4 wire connector, with the HVAC on "ECON" and the fan at "10", I measured 234 millivolts between the thick black wire and the thin "black" wire which I assume is the brown wire. Also, on the 2 wire connector, with it disconnected it shows battery voltage with the car off, and 0 volts with the car and HVAC on. Is that normal? Thanks! |
(Post 1587512098)
If there is zero volts on the red wire then there is something wrong (probably fusible link is blown). The large black wire with the red stripe should be around 12 volts when the fan is at 10. That is measured with respect to ground, which means a metal part of the engine or the frame. That wire goes to the blower motor. My car only has the one wire connected to the blower motor connector and a separate ground wire. I have seen later versions that have a 2 pin connector on the blower motor. |
(Post 1587512098)
https://cimg2.ibsrv.net/gimg/www.cor...6ab46dc6ef.jpg On the 4 wire connector, with the HVAC on "ECON" and the fan at "10", I measured 234 millivolts between the thick black wire and the thin "black" wire which I assume is the brown wire. If you unplug the four pin connector. Turn the ignition On. Press Auto button. Shouldn't matter what blower speed is selected you should measure around 10 volt DC on the Brown wire. If you do that indicates the HVAC Control head is good. No voltage the Control head is bad. That leaves the Blower Control Module or the wiring. The Red/Black wire appears to be burnt. That wire powers the Blower motor. With the plug disconnected if you manually apply 12 volts to that wire does the Blower Motor run at full speed? If it doesn't the wiring is bad to the Blower motor. If the Blower Motor runs it points to a bad Blower Control Module. You should always have 12 volts on the Red wire (Hot all the time) to the Black wire which is ground. |
Thanks for all the advice. I t looks like the control module is bad. The fan will run with 12 volts applied to the Black/Red wire.
I have ordered a new module, and will report back when I have it installed. Thanks again! |
UPDATE:
THANK YOU!!!!!!!!!!!!!!!!!!!!! The Blower control module arrived today. I just plugged it in and turned on the fan, and it fixed the problem! It did remind me how bad off the blower bearings are, so I will order a new blower fan. I am very happy to have a working fan as the State of Virginia requires that the defroster be operational in order to pass the annual State inspection (which expired on my 86' at the end of July). Thanks again!!!! |
