Want to add USB/AUX ports to my C6Z... And another stereo receiver question
So is there a way to add a USB and AUX port to my 2008 Z06 so i can play my music off my iPhone 5? I have the factory NAV head unit so i would be nice to be able to control it via the touch screen
Also my second question is, my car originally came stock with the non-nav head unit but the previous owner installed a factory NAV and everything seems to work great EXCEPT the steering wheel volume controls dont work at all, anyone have any ideas? |
You can solve both problems by installing a late factory NAV unit with the factory USB. The real early NAV units did not support steering wheel controls which is what you currently have.
GMs PAL or other audio adapters may be an option for the Ipod but will not fix the steering controls. |
I haven't used the newer Navs, but honestly I would upgrade the head unit. You will get the latest tech installed in a classy way if you go to a good installer.
I upgraded to a newer Kenwood unit with garmin nav. It is incredible and a million times better than an OEM unit. |
There's a way to splice into the XM receiver... If you search, you should be able to find the link. Pretty simple if I remember... And been wanting to do it to mine.
Ok if i upgrade to a newer double din headunit will there be a way to make the steering wheel controls work with it?
LFZ, I think i was looking at the thread you are talking about where you can splice into the XM channel |
Call Double D Mods and they will hook you up. Their have great prices and can have a unit pre-wired for you. It will come ready for the Steering control, onstar, etc. They even give you detailed instructions on how to hook everything up.
Originally Posted by RoadRebel
(Post 1587614747)
GMs PAL or other audio adapters may be an option for the Ipod but will not fix the steering controls. You can also add a PAL device which plugs into the XM reciever in the drivers side rear wheel well, interior portion.... Add: all other factory accessories will still function fine. |
(Post 1587614747)
GMs PAL or other audio adapters may be an option for the Ipod but will not fix the steering controls. Would I be controlling my iPod through the factory nav unit? Thanks. |
Originally Posted by LFZ
(Post 1587615739)
Originally Posted by Chevyfanaddict
(Post 1587630071)
I installed an Android head unit and a backup camera in my 2007 Z06 and documented it here. The steering wheel controls work.
https://lh4.googleusercontent.com/-z...0/IMG_4231.JPG https://lh3.googleusercontent.com/-y...0/IMG_4249.JPG https://lh4.googleusercontent.com/-r...0/IMG_4240.JPG |
What setup is that bjmsam?
Originally Posted by bjmsam
(Post 1587633961)
Do you use Torque through bluetooth or WiFi? If Bluetooth, then do you have any issues transferring phone calls to bluetooth? |
:cheers:
(Post 1587651007)
$327 for the head unit
$106 for the interface $33 for the camera $12 for the trim kit That's $478, but I sold my stock head unit for $414, so my total was $64. The OBDLink MX is a Bluetooth ELM327 device and does not interfere with phone call transfers. |
Im installing a pioneer nex 8000 in mine has all the bells and whistles and car play check that out on apples site if you like your Iphone at all you will like the stuff this does. This unit will take your maps over to Nav and you can zoom in and out by squeezing same as the phone.Going to load a flash drive (big one) to store big playlist and still use iphone for music as well. :cheers:
