Tune up recommendation help!
My 98 C5 is due for a tune up and I'm wondering what people recommend to use for new spark plugs and wires? Which ones give the best performance and so on? Right now my engine is basically stock, has a cat back exhaust and I plan on getting a new air intake and a possibly getting a tuner in the near future. Thanks for any input!
The red GMPP Performance wires and AC Delco Iridium plugs are all you need. You will not see any difference in performance, or any performance gains, from plugs and wires other than that realized by replacing old parts.
I like NGK...never had any issues with them. I do have to say, the rear plugs are not too bad to get out. Oh, pick up a new set of wires...mine were destroyed by just removing them and so was the PCV hose.
I agree with Ed, any name brand Iridium plug will do the job. Remember to get a dab of anti-seizure paste on the threads of the new plug before you torque them!
Originally Posted by Ray 2000 C5 FRC
(Post 1588096798)
http://www.firecore50.com
This is what I'll be buying. |
Originally Posted by kirt70camaro
(Post 1588096901)
Go look at how many drag race teams use them from pro stock to top fuel. Also the owner is on yellow bullet and seems to be an awesome guy. Never heard one bad thing about him and everyone loves his wires. He will make wires any length and ends that you want.
(Post 1588098103)
Originally Posted by Corvette_Ed
(Post 1588090488)
The updated OEM plug is ACDelco 41-110 (Iridium) and are pre-gapped to .040 |
(Post 1588098315)
I can understand using them if you need custom fits as most race engines require, but for stock applications they won't do anything more than the GMPP wires other than cost more. There is absolutely no performance gains to be had from plug wires, regardless of brand.
(Post 1588099546)
I agree that on a stock car there would be no performance gain. If a person were to be running heavy boost or nitrous then thats differnt.
MSD wires and NGK plugs are what I run. I did the wires about 9 years ago and they are still going fine. The plugs I change every year or two since I run regular NGK copper. If you do not want to change the plugs a lot go with some iridium NGK plugs. I use to run those in my S10 Blazer. They offered 100k change intervals.
Originally Posted by Sigforty
(Post 1588103874)
Red GMPP Performance wires and iridium NGK plugs
