Aluminum Radiators: Be Cool vs Champion vs DeWitts
Good Afternoon To All, I'm looking at getting an aftermarket radiator for my '96 LT4. Has anyone out there had experience with either the Be Cool, Champion, or DeWitts radiators for C4's? Any recommendations? I believe all are available as a 2-row, and Champion also has a 3-row available. Any opinions as to why I should go with one and not the others would be greatly appreciated. I'm looking for a quality piece that will help bring the normally high operating temperatures of the LT1/4 down to more reasonable levels, and for something that will hopefully stand the test of time.
DeWitts. No questions asked. Excellent product.
Oh, and don't get too carried away with temps... modern engines do run hotter and it is not a problem. It's because of all the divergent metals and emissions, that they have found the op temp sweet spot so that the metals all fit right and the emissions are not negatively affected. |
Originally Posted by bogus
(Post 1588702854)
Have yet to see evidence that a stock unit won't cover the needs of a stock engine. So, any of the 3 should suffice. I thought it was interesting that Dewitts actually blew up a Champion radiator for fun. Sounded like a bit of frustration over the lower-priced (and probably lower-quality) competition. I would have thought a better approach would have been to offer a swap to DeWitts for an existing (dissatisfied?) Champion owner. Would have been more impressive than blowing up a radiator for fun -- especially if a radiator swap (from Champion to DeWitts) cured someone's complaint.
Don't you think? |
DeWitts.
Main change I noticed was that temps came back down very quickly once the car started moving from a light. |
Originally Posted by GREGGPENN
(Post 1588703118)
I would have thought a better approach would have been to offer a swap to DeWitts for an existing (dissatisfied?) Champion owner. Would have been more impressive than blowing up a radiator for fun -- especially if a radiator swap (from Champion to DeWitts) cured someone's complaint. Don't you think? Until the next guy with a bad champion comes along. I would expect anyone to replace my radiator because of my choice. I would have loved it if AFR came in and offered me their heads to replace the junk TFS that I got but that is kinda far out there. |
I just ordered a Champion 3 row so I hope they are decent.
I have been using a Champion radiator for nearly 4 years in my 96 coupe with no problems. In the summer at freeway speeds generally runs 192-196 and in the 204-209 range when stopped which seems pretty decent for North Texas summers. Keeping any radiator clean is the most important thing
Originally Posted by pologreen1
(Post 1588706125)
Where are these made? While our radiators are manufactured in China, hence the low price point, they are designed in the U.S. If an American made radiator is preferred instead, please call us for availability. There will be a price difference to accommodate the American labor being put into it. A standard 2-row is $169.98, and an American made 2-row with 1" tubes is $279.98 |
I think anyone of those will work just fine!
Question is? for how long. This is why I decided to go with a known Quality Radiator, and be done with it. |
(Post 1588702854)
Originally Posted by desertmike1
(Post 1588707025)
I always get a kick out of high water temp because of the wrong radiator threads. My temp hit 178 last year. Yes below the thermostat. And it's because of a new AC Delco stock radiator installed after the original cracked on the plastic side. '96. Cruise is 185-190 year round.
The fans are programmed to on at 206. NEVER above in years, and it cost $109. The idea that the late C4 radiator is inadequate is incorrect. |
I have a direct fit fluidyne and a 3 row champion radiator. The only advantage of all the direct fit units is ease of installation.
The champion unit is top quality and if not being a direct fit, would be hands down the best radiator for the C4. |
Originally Posted by pushrod-v8
(Post 1588710269)
The champion unit is top quality and if not being a direct fit, would be hands down the best radiator for the C4. Mine might not work, but I am ordering the wrong one anyways so it will need mods to fit the car. Fit is not the concern, price and leaks is. Champion seems to have a shot at satisfying both needs. A radiator is a radiator. Engine building, paint job or furniture work is not always equal and there cost cutting is noticed.:smash: |
I run a BeCool because I got a great deal on a new one. I've installed a few Dewitts in other cars and they fit great. One is cooling a 650hp road race car with their fan upgrade in an 86. If I ever need one again for my 96 it will get a Dewitts.
(Post 1588710269)
The champion unit is top quality and if not being a direct fit, would be hands down the best radiator for the C4. I'm having a hard time accepting "Made in China" and Quality" in the same sentence. |
I installed a Dewitt's in my 88 about 6 years ago and really talked them up on the forum. Then a little over a year later it started leaking. It appeared the drivers side upper left solder was inadequate and it was leaking around the tubes. I tried epoxy, then cut off a portion of the side tank and epoxied it from the inside, which blocked two or three tubes. It started leaking again. I went back to stock then last year installed a Champion three row and it appears to cool just as well as the Dewitt's. I had no problems with fittment and it looks good.
I hold no ill will toward Dewitt's, they make an excellent radiator. I may have just got a lemon, but I didn't want to take another chance with them. |
Originally Posted by Corvette40
(Post 1588716187)
http://www.dewitts.com/pages/warranty
