School me on drag radial/slicks sizes and what fits
I am looking to get a set of rear tires to use only at the track, since I have no traction with street tires. My car has a 4 speed and I was originally considering Drag radials since I plan on driving the car to the track with the regular radials and changing the rears to race. I didn't want to mix bias ply slicks in the back with radials in the front so drag radial were my choice. However I see MT makes a radial slick. I am thinking of going with that. I have a 2 extra corvette rims for my 81 so that is what I will be using. I currently have goodyear 255-60-r15. The MT drag radial for that size shows the tire as 27x10.5. It says the approved rim size is 7.0-9.0 and Measuring rim is 7.5. my first question is can I use my rims with that tire and it fit on my car. Now if so and I went with the radial slick they have it comes 26x8.5 or 26x10. The site doesn't list an approved rim for those but for the 8.5 the measuring rim is 8 and for the 10 inch the measuring rim is 10. Would I be able to use either of those? Sorry if this is a dumb question, I just have no idea yet and wanted to get some information before I do anything.
I find that the MT techs know their tires pretty well. You could just give them a call and probably get all the info you need. Be ready to tell them about your engine, trans, rear gears, weight of the car, etc. A couple of quick questions- do you drive the car much on the street? Does it hook on street tires when on the street? What's your power level? I ask because their ET Street Radial works for me on the street and at the strip. If you get a slick for the track but use regular tires on the street you're only solving the problem at the track- assuming you have traction problems on the street. Here's the tire I use in a 255/60/15-
http://www.mickeythompsontires.com/s...ETStreetRadial |
Originally Posted by Les
(Post 1589057352)
I run 275/60/15's on my '69. Mickey Thompson ET Street Radials. They stick out just a tad but doesn't look tacky IMO.
1 Attachment(s)
This is 275/60/15 BFG drag radials on stock 8 inch rims. They are 27 inches tall. I had to move the parking brake cable bracket for clearance. My car is an automatic, but I can't believe drag radials won't provide enough traction for you.
Attachment 48191065 |
I run MT ET Street radials 255/60/15 at the track, they hook well on a prepped track. They bolt right on and fit well.
275/60/15s will fit if you relocated the parking brake cable bracket on the trailing arms. I run Nitto 555R 275/60/15s on the street and they look great on stock 8" wheels. The best hooking tire you can get is the MT ET Street radial PRO 275/60/15. It would work great if you have enough gear to pull 28" tires. |
i know nobody recommends wet weather use but anybody have any input on one brand over another if you get caught in that situation? I've had people say nitto is good and others say they are all about the same. and do any of them hook better on the street ?
Originally Posted by 7t9l82
(Post 1589069024)
(Post 1589069024)
If I drove in the rain often, I would stick to a BFG radial TA but....for occasional rain use, I think the Nitto 555R is pretty safe...(atleast for a drag radial). The tire actually hooks pretty decent too... For 500 crank HP or less, I think its a great street tire. MT ET Street radial and Hoosier drag radials are straight up dangerous in the rain. I have driven them both in the rain, I keep it at 30 mph or so...no joke... Also the Nitto NT-05 is terrible in the rain. |
I'm running a 315/60/15 Mickey ET Street on a 15x12 with 4" backspacing and it fits great with 0 chassis modifications and no spacer. I did have to run longer studs and I will be adding flares to cover the poke but surprisingly the frame didn't need to be modified nor did the parking brake bracket.
https://cimg4.ibsrv.net/gimg/www.cor...b8757004e3.jpg |
Originally Posted by ajrothm
(Post 1589084166)
I run Nitto 555R 275/60s on my car for daily use, I've had them in the rain several times and never had an issue... I did slow down to about 60 on the highway as opposed to my normal 70-75 but never had a slip.... The tread depth is actually pretty deep on the 275/60 Nitto.
I have a friend that got caught in the rain on a set of 275/60/15 bfg drag radials and said it was like a pig on ice, he switched to Nitto 555R of same size and says they are as good in the rain as a normal street tire.
thanks for all the advice. I don't plan on driving it in the rain, and won't even be driving to the track with the tires on, I'll most likely be putting them on when I get there.
Originally Posted by jaybird81
(Post 1589088979)
i ordered the nitto's this A.M i cant wait. i read on another forum that guys used them in front too for autocross, does that even seem possible?
(Post 1589089084)
Track only = MT ET Street radials... no doubt about it.
(Post 1589093414)
I've run Nitto 555R's in the rain and they were fine. I've run 18" MT ET Street Radial II's in the rain in a big hp car (Power Tour) - I don't recommend it, but you can do it. I got caught in the rain on well worn BFG drag radials and it was straight up scary. But hell, I run Hoosier R6's on the street so what do I know.
Well my new Nittos made it here before noon today. probably sometime next week i will get them mounted. i have heard drag radials leak out air pressure and have heard use slime ( which i don't care for ) or wipe the inside with Dawn. A friend in the tire business says use Nitrogen And carry a tank filled with Nitrogen to the track to air up.
also what type of pressures are you guys using, i understand that changes with temperature and track conditions. |
(Post 1589121605)
