Window stop for 94?
Hey guys, my driver's window goes way too high and I believe the driver's front window stop is broken. I'm having trouble finding a new one. Anybody know who sells them?
Originally Posted by bassackwards
(Post 1589531180)
Check #62 in this image. If you're asking someone for a "stop" they're looking at #41 which is NLA. The LH guide should be available still. http://parts.nalleygmc.com/showAssem...=0&modelYear=0 |
Originally Posted by WVZR-1
(Post 1589531310)
In '93 door/window changed - do you want the stop that's bolted to the door frame or maybe the guide that's attached to the glass?
10243037 and 10243038 are the guides (left and right door) and are what will bump up against 10263155 common part (left to right door)
The stop will more than likely not be broken as it is a metal angle with a felt pad on it, you will want to make sure the pad is not missing, it bumps up against the plastic guides that you will find broken. Guides http://www.ebay.com/itm/1993-1996-C4-Corvette-Front-Door-Window-Guide-Right-GM-10243038-/161672872555?hash=item25a474426b&vxp=mtr |
To update this thread I'll post that the window guide replacement as posted above did fix the over travel problem. The bolt holding it on the glass was Loctited on and was very difficult to break loose.
(Post 1589832057)
Already finished with no pics. Sorry.
Originally Posted by antfarmer2
(Post 1589832077)
Please post as many pics and info as you can need to play with my 94. I let a freind drive it and he used the window to pull himself out.:toetap:
http://i30.photobucket.com/albums/c3...r/DSCN5109.jpg http://i30.photobucket.com/albums/c3...r/DSCN5099.jpg http://i30.photobucket.com/albums/c3...r/DSCN5103.jpg I'm not sure if this is helpful at all, but this is the only photo I took of the door when I was doing this repair about 12 yrs ago or so I think. This was the passenger door, so the driver's side door part number will not be the same...will end in 7 rather than 8 as the PN in the photo above shows, just like higgyburners posted above. http://i30.photobucket.com/albums/c3...r/DSCN5105.jpg |
Same Problem
Thanks for the info and pictures. I have the same issue with my '93.
Originally Posted by Opihi59
(Post 1589842428)
If we're talking about the same part, here you go.
