Anyone use Toyo proxy R888?
Thinking about putting a set of 275/40/17 & 305/35/18 R888 on my z06 stock wheels. Any one run this set up? I have used tripe eights before on my isf but didn't now if there's a better choice for a weekend track Z.
That or NT01 in the same sizes if you want a R comp. More street tire oriented your options are 275/295 NT05 or 255/285 RS3.
Originally Posted by Darbs
(Post 1589643734)
^ Same here. Great setup.
Had these sizes ony car when i originally bought it. Great handling daily driving.
1 Attachment(s)
(Post 1589643734)
Attachment 47887199 |
Oooops, guess the file is a tad large, size does matter.
Originally Posted by John Holmes
(Post 1589686307)
Mine provided better grip at 36 psi than the Toyo recommended
How much of a bigger tire can the stock z06 wheels hold ?
All available Toyo R888's are in stock and ship FREE from PTS!
Originally Posted by Street Approved
(Post 1589693595)
If you don't want the same diameter tires up front as out back, you'll have to choose your front tires carefully with the 25.5"-tall 315/30 (the 24.7" 245 or 25.1" 255/40-17, for example, should work fine with the TC/AH system) |
Originally Posted by rjwz28
(Post 1589695486)
I don't know what size you're trying to fit, but both the 305/35-18 and 315/30-18 R888 are spec'd to fit on a 10.5" wheel
(Post 1589697529)
I was going to replace my tires soon....and I don't know a damn thing about numbers in the rubber. So darn said he had stock z06 rims with 275 front and 305 rear. I didn't know stock z06 could hold that.
I'll be running these on my new rims...
running these in 295/30/19 front and 345/30/19 on my new wheel/brake/suspension setup to be completed this week :thumbsup:
(Post 1589697529)
The 275/40-17|305/35-18 combo will fit fine on factory wheels http://www.tirerack.com/tires/tires....el=Proxes+R888 :thumbs: |
The 275-305 maintains factory ratio for the most part. What's happens to your speedo with the 315 in the rear?
(Post 1589705683)
I have a set on my car and other than being extremely noisy I like the way they drive and handle. Even in the rain they are pretty good
(Post 1589643734)
