Centering Bellhousing Question...
This is/will be my first attempt at doing this...I have the dial indicator ready to attach....can/should i attach it to crank or offset it to flywheel?
And for reference its a small block..also is there a video i can look at for reference? TIA |
You tube has a few on this subject. Look in my thread about clutch not releasing and there are a couple link in there.
been there very recently, never done it before!
You can read my findings and pictures in this thread post 24 https://www.corvetteforum.com/forums...-repair-2.html A great 'how to' article is here http://www.hurst-drivelines.com/wp-c...d-6-15-09A.pdf It took offset dowels to get it right. video I liked was this one |
The problem im having is centering the dial up to hit the edge....just can't figure out the combo of all the moving parts..its a real 'pia' when its still in the car...:ack:
Jack, it has to attach to the flywheel face,,, the crank will give you bad readings. I struggled, and finally I purchased the slip-fit alignment tool.... Waiting to get the engine off the cradle to use it.
I centred it without pressure plate, clutch. Magnet base dial mounted on the crankshaft flange.
Originally Posted by DucatiDon
(Post 1590330332)
There isn't enough face on the crank for the magnet to attach and travel in a circle....it can only attach to the face of the flange where it travels in an ellipsis . You need the base to rotate around the axis of the crank, not rotate with the crank..if that makes sense...
I got the magnetic base one...flywheel still attached...it attaches but when i try to move the arms for adjustment the damn thing comes loose and I am getting frustrated....
What is a 'slip fit tool' and what does it look like? |
It bolts to the crank flange and has a ring that slips on..if it passes thru the bell housing it aligned correctly.
https://www.google.com/search?q=bell...2sruF2ZMz6M%3A |
(Post 1590330487)
https://www.google.com/search?q=bell...2sruF2ZMz6M%3A OUCH...I cannot justify spending that type of $$$$ for a one time use... |
(Post 1590330431)
Originally Posted by 66jack
(Post 1590330446)
To center the hole in the bell housing on the crank axis with a dial indicator that has a magnetic base, just stick it to any portion of the flywheel which provides a stable mount. Of course, use offset bellhousing dowels to shift the bellhousing up/down, left/right as needed. http://i580.photobucket.com/albums/s...c/P8280110.jpg After you have the bellhousing centered, put the tip of the dial indicator on the transmission mounting surface of the bellhousing and verify that the bellhousing is perpindicular to the crank axis. Use shim stock between the bellhousing and the block to change the angle of the bellhousing, if needed. http://i580.photobucket.com/albums/s...psoy3j7xao.jpg And that's pretty much what you can do with the engine in the car and the bellhousing attached to the block. With the bellhousing off, though, you can mount the dial indicator stand on the block and use the tip of the dial indicator to check for flywheel run-out. Sorry no picture. Overall, this is not a fast process, but neither is it difficult. Jim |
while you are it, the problem I encountered may be of interest.
After aligning the bell (without the clutch in place) the gearbox went in like a dream for a test fit. Then, I unmounted everything, installed the pressure plate and the clutch (using the clutch alignement tool), reinstalled the bell housing and ..failed to get the gearbox slide back in. I think I mounted/unmounted 4 times (everything, including clutch&Co!) to see what I did wrong. Finally I found the alignement tool (that came with the gearbox kit) to be the problem. The fit in the pilot bushing was too loose (only slightly) , and the pressure plate assembly dropped somewhat under gravity before tightening the bolts. Result: everything was aligned , but the clutch disk (with the slots that grab over the gearbox axle) was not. So the slots blocked against the gearbox axle rather than slipping over it. I put some thin tape over the tip of the alignement tool to have it tight fit in the pilot bushing, and voila, problem resolved:thumbs: But even then slipping the gearbox in needed a delicate handling. The tip of my gearbox axis is chamfered (RS400), and the very sharp chamfered edge acts like a chisel on the soft metal of the pilot bushing. I read many posts where people start wiggling the gearbox until it fits, I am afraid that does not work without damaging the pilot pushing. I rounded that edge off to take out its sharpness, and the box went in much more easily:thumbs: |
Like i said...first time trying this and I still cant figure out the combo to get this thing to work...the shaft on the holder is too long to attach to flywheel...it hits the bell housing, if i try and attach to crank I cannot get the combo of angles....:rock:
I'm giving up for today......4 hours of frustration and nothing to gain...:toetap: |
(Post 1590331506)
You need a different set of shafts / extensions for the magnetic base, and maybe a different magnetic base and dial indicator.
I ran into the same thing when I recently did a bell housing. My "good" magnetic base and fixed rod (on the base) was too long, so I had to use my old lower profile base & rods. Those rods are thinner, so the wgt. of the dial indicator is important (a heavy dial indicator may cause the indicator to move or cause the magnetic base to loosen / move). Recommend the McRobb offset pins, if you need them. Good luck, Plasticman |
Originally Posted by jim lockwood
(Post 1590331805)
Post a picture of the configuration you are trying to make work.
http://i83.photobucket.com/albums/j2...ps1yaqogze.jpg http://i83.photobucket.com/albums/j2...psduoycikn.jpg |
(Post 1590331910)
These are not the combo's i tried, its just pictures for you to see what im working with...
http://i83.photobucket.com/albums/j2...ps1yaqogze.jpg http://i83.photobucket.com/albums/j2...psduoycikn.jpg Some folks use steel flat stock about 1.5 inches x 4 inches x 1/8 inch thick to make a "bridge" piece that goes across the crank flange to provide a secure center mount for the dial indicator base. Drill a couple of holes in it to mount it securely to the crank flange/flywheels bolts. This allows you to center the dial indicator mount without any wobble or misalignment. A few years ago, I put together a presentation for NCRS on doing these bell housing checks and corrections. I used my own personal experiences as well as two or three of the best videos out there to put together a "best practices" way to do this job without issues or hassles. Designed for the novice, but also good for experienced guys. If you want or need a copy let me know. The procedure itself is less than 1 MB, but with all the pictures is around 30MB...............a bit much to email. But let me know if I can assist. Use of the Browell alignment tool is also discussed as a second way to do this job. But I like the standard dial indicator method for occasional/infrequent use. I also agree with Plasticman on use of the McRobb offset dowels.....................use them and not the others. Larry |
Originally Posted by Powershift
(Post 1590332154)
Jack:
Some folks use steel flat stock about 1.5 inches x 4 inches x 1/8 inch thick to make a "bridge" piece that goes across the crank flange to provide a secure center mount for the dial indicator base. Drill a couple of holes in it to mount it securely to the crank flange/flywheels bolts. This allows you to center the dial indicator mount without any wobble or misalignment. A few years ago, I put together a presentation for NCRS on doing these bell housing checks and corrections. I used my own personal experiences as well as two or three of the best videos out there to put together a "best practices" way to do this job without issues or hassles. Designed for the novice, but also good for experienced guys. If you want or need a copy let me know. The procedure itself is less than 1 MB, but with all the pictures is around 30MB...............a bit much to email. But let me know if I can assist. Use of the Browell alignment tool is also discussed as a second way to do this job. But I like the standard dial indicator method for occasional/infrequent use. I also agree with Plasticman on use of the McRobb offset dowels.....................use them and not the others. Larry Pictures are better for me...I, at times have problems visualizing...:rock: |
