WTB: Dipstick for 68 427, Thanks!
Hi, looking for a good used dipstick and tube for 68 427 engine. Stick will read from bottom to top: ADD/ /FULL ENGINE OIL E (The "E" is on its side). Typically it will have a pink or salmon color plastic tip. The handle will be round and slightly flattened. Let me know if one is floating around out there. Thanks! :woohoo:
Originally Posted by tfringo
(Post 1590373030)
I have one that I received from an NCRS member who had a 68 BB (400 Tri?). It reads as you posted, but has an off white tip. Never could really ID what it was from. |
Originally Posted by avalonjohn
(Post 1590373849)
It reads as you posted, but has an off white tip. Never could really ID what it was from. John |
There seems to be some question about this.
It might be true. But, I have seen pink/salmon in a couple cars. Sometimes the tip is missing. Thanks :cheers:
Originally Posted by JC68
(Post 1590377329)
White is the correct color tip for all 68 big block dip sticks. It was also used on most 69s.
John |
I just checked my 68 L68, it's stamped as described with the off-white, almost tannish colored tip. What color is the handle supposed to be? Mine is silver, but it looks to be spray painted and there was some overspray on the white tip that scraped off with a razor blade.
Hi,
For the most part, the consensus is the tube was natural color and he handle was natural color. Both seemed to quickly change to rust color. :lurk:
Originally Posted by mooncricket
(Post 1590378132)
(Post 1590378270)
:cheers: |
(Post 1590377868)
John |
Hi again, ,
John,
Do you have a list of other 68 parts you are going to sell. Any luck on the drivers side dash pad? I am interested in the antana if it is in oK shape. Looking forward to seeing the dipstick. Thanks, Terry :cheers:
(Post 1590373849)
[. Looking forward to seeing the dipstick.
Thanks, Terry :cheers:[/QUOTE] Rest assure, Terry. Anything purchased from AJ is going to be exactly as described if not better. I purchased parts from John and never had any regrets. AJ is a top shelf seller and all around good guy. :thumbs: |
I am sure it will….
I talked with him a little bit today. I am worse than a little kid around Christmas time. :ack:
Originally Posted by bkvette3
(Post 1590440852)
Thanks, Terry :cheers: Anything purchased from AJ is going to be exactly as described if not better. I purchased parts from John and never had any regrets. AJ is a top shelf seller. :thumbs:[/QUOTE] |
Terry,
Contact this guy for early C3 parts, indicate Joe Hudec pointed you his way. VETTSTEVE@AOL.COM Not sure he has a lot of BB stuff, but he is located in southern ca and has parted and still is parting early C3's 68's, 69's etc. He may a few things you are looking for? Joe |
