TPS fault diagnosis test
Just made a backprobe test on my 1995 tps...
black voltmeter pointer on grey tps connector wire, red voltmeter pointer on battery terminal, key on Reading is 0.01 and stay there, no move on... Can we say it's time to replace it? |
On your car the TPS is non adjustable, and the minimum is set by the ecm when you turn on the key...With key on the TPS should read around .6 volts, and while moving the lever to WOT the voltage should move up smoothly without any voltage drops up to around 4.5-4.6..If you meter isn't showing any movement , and the wires are hooked up right , then it's time to replace your TPS..:thumbs:....WW
Originally Posted by WW7
(Post 1590559354)
On your car the TPS is non adjustable, and the minimum is set by the ecm when you turn on the key...With key on the TPS should read around .6 volts, and while moving the lever to WOT the voltage should move up smoothly without any voltage drops up to around 4.6-5.0..If you meter isn't showing any movement , and the wires are hooked up right , then it's time to replace your TPS..:thumbs:....WW
1 Attachment(s)
What chiltons says its a little bit strange....
"The voltage should read less than 0,5 volts" I think with minimum open throttle it should be around 0,54V |
Originally Posted by Christi@n
(Post 1590559374)
First of all, I would say that I've made a mistake, chilton's manual say to read voltage at TPS connector blu wire not grey, so i need to came back to the car and make a new read
PS...The .54 is for a L98 engine, the LT1 starts with a slightly different reading. You just want to have a smooth voltage progression with no dead spots or fluctuations as you move the throttle upward....WW |
(Post 1590559402)
The reason I'm not familiar with what wires to hook to is because I always set mine with a scanner...Scanners are quicker...:D...WW
PS...The .54 is for a L98 engine, the LT1 starts with a slightly different reading. You just want to have a smooth voltage progression with no dead spots or fluctuations as you move the throttle upward....WW Anyway there are two strange thing No possibility to get it lower then 0,60v this is full unscrew TB screw... It won't go over 4,64 v as higher voltage What I'm searching for is the right voltage to set lt1 Tps via TB screw |
If you have a 95 Corvette your TPS is "NOT" adjustable..You just screw it in and your finished...If your reading goes from .60 to 4.64 without the voltage dropping, then there's nothing wrong with your TPS......The only ones that are adjustable are on the older cars..You can screw the TB screw all day and it won't change the settings on the TPS..But you will mess up your idle adjustment...:banghead:... .WW
(Post 1590563305)
If you have a 95 Corvette your TPS is "NOT" adjustable...You just screw it in and your finished..The only ones that are adjustable are on the older cars..You can screw the TB screw all day and it won't change the settings on the TPS..But you will mess up your idle adjustment....:ack: .WW
THOUGH screw on TB side moves shaft and blades as result it moves even tps on the other shaft side located My problem is that screw was been messed |
A normal multimeter is typically too slow to register a voltage drop off in some cases. While some multimeters might display the drop, I recommend a graphing meter.
Originally Posted by DanielRicany
(Post 1590563476)
here our friends mention about 0.64 v with minimum open throttle. infact mine wont go under 0.6 v. but I can increase it a little bit tighting TB screw |
(Post 1590563566)
https://www.corvetteforum.com/forums...lp-needed.html
(Post 1590564638)
You don't have to worry about if it's .6 or .64 or whatever as long as it's close, because the cars computer ( ECM) will figure out what your low reading is and will set it for you from there...Your making this much harder for yourself then it has to be....:willy:....WW
The PCM reads the TPS voltage when you turn on the ignition and saves that number and calls it "idle". It should be approximately 0.6 volts for non-adjustable TPS sensors. |
Ok i've got it...
But what is the TB idle screw purpouse?i've heard many times that there's a plug on it, and is a good thing do not mees with it Chris |
(Post 1590566337)
Ok i've got it...
But what is the TB idle screw purpouse?i've heard many times that there's a plug on it, and is a good thing do not mees with it Chris . . |
(Post 1590566381)
The idle screw is to adjust the amount of air that the engine needs to work properly with the other components of the engine.. If you have moved the screw off of factory settings you would have to do a "minimum air adjustment" to get it back where it belongs...WW
. . do you know what need to do in order to get a minimum air adjustememt? |
(Post 1590566456)
Yes I've done it,
Originally Posted by Cliff Harris
(Post 1590572621)
I've already try to this some months ago, but my idle no go under 850-900rpm |
(Post 1590576699)
(Post 1590578091)
It will if you turn the "idle" screw enough. As you take away the air, the idle speed has to slow down.
The reason is that at some point, TB shaft has a stop that is screw unconnected with it So i can turn screw again and again but idle stay there. This point that i would to call "zero" match 0,60v on TPS and 850-900 rpm |
Either your throttle body is too dirty to allow the throttle blades to close all the way...
Or, you have a small vacuum leak somewhere causing the higher idle... Or, your ECM is commanding the IAC open too far for some reason Or, your IAC is not acting correctly. All except the first are easy to spot with a good scan tool. Those plugs on on the throttle body so people don't screw around with them trying to fix it the WRONG way. Not a dig at you but I've seen that before on GM throttle bodies. Dumb question does it idle at that RPM ALL the time? A/C on and off? In gear and not in gear? Hot and cold? |
