Can LS1-Edit Copy and Flash the stock program.
I mean..If I have a copy of my stock flash (as a backup before making changes) Is this an exact and complete copy? Just like the dealer would have? And if I flash back to stock later.. Does it write the complete code back just like the dealer?
I want to make sure I don't go blazing any new trails I can't return from... |
Re: Can LS1-Edit Copy and Flash the stock program. (chuckster)
It only writes the data segment back (not the code segment) but it does write all of it. You cannot use it to install a factory flash in a fresh PCM but you can definitely save your existing stock programming and completely revert back to it if needed.
