Exhaust System
Looking for an exhaust system for my 1970 corvette 350/300 hp. I'm trying to stick to an original or a good reproduction. The originals are very hard to find as everyone knows. I really don't have a clue about the reproduction quality.. Looking for some suggestions. One of the few items left on my restoration list.... thanks Droop
Originally Posted by Alan 71
(Post 1591562588)
Hi Droop,
The stock aluminized welded system from Corvette Central is one you might want to consider. It installs very easily and fits well. It's available with either the stock type mufflers or a N11 off road mufflers that have one less baffle in them so give a bit louder sound. If you can be patient for a little while CC often has free shipping specials which will save you a little $$. I was really quite surprised and pleased how well the system fit on my 71. Good Luck! Regards, Alan |
(Post 1591562588)
Hi Droop,
I like the color:D
Marshal
Originally Posted by Droop
(Post 1591562454)
I used the CC system with Magnaflow mufflers. Not the welded one though.
It does fit very nice. http://i1235.photobucket.com/albums/...pszv3bpzvd.jpg |
Originally Posted by marshal135
(Post 1591566865)
I like the color:D
Marshal |
(Post 1591566728)
Hi Droop,
Yes, I bought the welded system. I too was concerned about how the tailpipe/muffler would fit, but was pleasantly surprised. It appears CC must have a pretty precise jig for the pipe and muffler to get a consistent positioning before the weld. The system was easy to install and getting the exhaust tips centered in the valance bezels was straight forward. What I like is not having the extra set of clamps between the mufflers and pipes and that the pipes tucked up very high as they ran under the rear spring mount so you don't see them hanging down. I'm sure not everyone is as pleased as I was but I really thought they were good. I bought the sb, 4-speed, aluminized, welded, system for a 71. Regards, Alan |
Originally Posted by ddawson
(Post 1591567869)
(Post 1591570281)
Dan, Did the system come with bands or clamps? Droop
It came with clamps but I like to use bands instead. I think I'm going to have it welded this spring. It's not like I plan on taking it apart again anytime soon.
Alan, great pic! I was starting to doubt that the double wall existed!
Droop, I can vouch for the fit/finish on a Gardner exhaust, installed one on my 68 and the fit was perfect. |
I bought the true dual exhaust from CC. I love the rumble,easy to install. I have the hideaway mufflers. They fit great on my 76. They are Magnaflows.
(Post 1591574241)
Hi d74,
What's going on at the other end of the front pipes is even more interesting! Regards, Alan http://i218.photobucket.com/albums/c...DSC_0090_1.jpg http://i218.photobucket.com/albums/c...s/DSC_0095.jpg |
(Post 1591577237)
Hi Droop,
The pipes and mufflers I'm trying to put together are service replacement pieces. They're not totally correct for my 71, but are about as close as I think I'm likely to find at this point. The pipes are carbon steel so they rust while you stand looking at them. I have cleaned the rust that was on them, (surprisingly little), and have a preservative on them now. I really am only trying to put the set together in anticipation of perhaps having the car Flight Judged for it's 50th birthday. If I were to begin driving my car I'd put the CC aluminized system back on in a heartbeat. Putting an exhaust system together and finding original tires really isn't just about the points because there aren't that many involved…. but is much more about pushing the envelope for an ordinary car that typically wouldn't get this much restoration attention. Regards, Alan |
Call Aliens Stainless, his system is top of line and fits perfectly
Mine is a 2 1/2 system and went together with zero issues.....I think he's a vendor here.....and easy to communicate with which is also important .....plus he makes the parts no third party involved.....:thumbs: . |
Alan
Did you go with the 2 inch pipes or 2 to 2 1/2 set up? jesse |
