Suspension Porn
http://i198.photobucket.com/albums/a...shzzfghye.jpeg
With my new found power (680 RWHP) during hard acceleration my rear quarters meet the 295-50-16 M/T drag radials. Obviously not the best way to start a race. I ordered a set of Viking double adjustable coilovers and so far they are everything I was hoping they would be. Direct bolt in and took about 2 hours to install. With a 600lb Spring they are a bit stiffer than the stock leaf and ride height is 1/2 an inch lower by just hand tightening the coilover adjuster by hand. I'll post some results when I get an opportunity to take a ride. |
They look good. What made you choose the brand?
I did some searching on a couple forums and a few guys had good arguments why you don't need to spend huge money on other brands. Brands like menscer and santhuff. They also won Best engineered product at 2014 SEMA and I believe it was for their shock valving. Customers service was very good and the price was right. They are 22 way adjustable , the crusader line.
I'm thinking about picking up a set. where did you purchase from?
I dealt with Jake from Viking and bought them directly from Viking. There are a lot of vendors and eBay who have them available as well. It cost me an extra $40 to order from Viking because they don't compete with their distributors. The tech advice and product information I received made it worth it.
I'm looking to purchase a set as well. How did you decide on the 600 lb springs? I want to do a full set front and back, but not sure what spring rates to choose.
Do you have a part # for the rears? |
Originally Posted by 95vettski
(Post 1592940854)
Do you have a part # for the rears? To get the spring rate I read a little about what other guys with similar combos are using . I also spoke with a representative and we compared notes. I wish I could put a number on how much firmer it is over the factory leaf. All I can say is that it's a little firmer. Takes a good push on the deck lid to get the rear to squat. |
looking forward to some testing results and overall thoughts too.
i have LG coilovers now and not a fan of them at all and looking to replace them with these. did you do all four corners are just the rear? |
Originally Posted by neverstop
(Post 1592949023)
Originally Posted by junk c5
(Post 1592941532)
VRV395AM-600K is the item number.
(Post 1592951508)
Thanks for that. I was looking at Viking's online catalog and did not see your exact part number. It shows VRV395AM-700k which I'm assuming is reference to a 700 lb spring. Is your part# a typo or did you custom specify that spring rate?
Got an opportunity to go around the block and get a couple hard hits in. Right off the bat I could feel the firmer ride which isn't to firm. Driving to lunch with a buddy the car didn't grab the tire on the dips like it was previously so that's a step in the right direction. The rear does sit 1/2 an inch lower than with the factory leafy. During HARD acceleration it seems like it just barely grabs the tire. I'm thinking I'll raise the rear up 1/2 an inch and put 2 clicks in the compression to stiffen it and that should solve my issue
Just a little info to add.... With a Hoosier drag radial and 700lb springs the car worked well. I switched to a full M/T slick and the car kept unloading the tires a couple hundred feet out. The rear end had very little downward movement, it was super tight. I changed out the springs to a set of 10” 600lb and it’s a lot looser. I’m hoping to get a decent amount of weight transfer to keep the tires firmly planted. This is on a no prep street type surface.. I’ve seen a better hooking street in the middle of a corn field. I’m sure on a prepped track they will work well but the no prep surface is tricky.
I was able to get some results from a recent no prep event I ran. In addition to the 600 pound Springs, I also changed over to a Hoosier slick with the D06 compound. I was able to throw more power at the car than I ever have. Every round I added more power and was amazed I was able to put it down. Unfortunately, I got taken out in the finals by an all wheel drive car. There is another event at the end of the month and I’m going to throw a ton of power at it and see how much the worst racing surface I’ve ever been on will take.
