For torque managmt via LS1 edit on the WOT upshifts on A4, what do i set parameters to
I heard that the latest ls1 edit allows for different parameters for torque managment on WOT upshifts and also heard that 0s should be put in for these paramters. SInce installing radical 4000 stall drag converter and 3.73s i am having an intermittent problem (where it feels as if my engine cuts out for second and then starts accelerating again) right after my WOT 1/2 shift which i believe is related to torque management.
Am i correct in setting all of the parameters at 0 for torque managment on the WOT upshifts on my 98 A4 vert? Thanks, Nitrovette |
Re: For torque managmt via LS1 edit on the WOT upshifts on A4, what do i set parameters to
Check out http://ls1edit.slowcar.net/faq.html
There's a section on transmission. Look under torque management. :yesnod: |
Re: tq mgmnt via LS1 edit on the WOT upshifts on A4, what do i set parameters to (Nitrovette)
You only have the problem of TM kicking in from 1-2 about 15% of the time. Try setting below your current setting. Anybody know if upshift TM can be set by gear? Jim, your probably not hitting your rev limit from 1-2?
Re: tq mgmnt via LS1 edit on the WOT upshifts on A4, what do i set parameters to (jfpilla)
Joe:
Your right, i am not hitting the rev limiter when the 1/2 shift occurs or anytime relevant thereto. THis bug occurs right after the 1/2 shift occurs and happens like you say only about 15% of the time. The problem is that my tuner tells me the tm is already set at 0 for the 1/2 shift but can be lowered for the 2/3. Will lower or shut off any tm parameters that we can to see if this helps. Thanks for all your help and input. Nitrovette |
If it is a TM issue one of the systems that uses TM is sending a command for it. So I agree you need too turn everything related off. Does your tuner have the upshift feature? Does it seem you might be getting spark retard after you are in 2nd? Isn't there a spark retard feature for 2nd gear ?
