Battery Tender questions
After getting a number of opinions, I'll be getting a battery tender for storage. I'd like to hear opinions from some CF members on what is the best tender out there with an eye toward function, reliability and (perhaps above all) safety. Also, should the battery remain hooked up in the car while the tender is also hooked up? Lastly, I've read that when a battery is being charged it will emit fumes that can be rather dangerous. Is that a concern while having the battery on tender while in an enclosed garage? Thanks in advance for any assistance.
I have used a Deltron Battery Plus since 99 on the vette in the winter and in the summer when its going to set for more than a week,never any problems,it does not charge it just mantains your battery. Amazon has them for $49.99.
Like anything else, you're going to get a multitude of opinions on this as well. I've been using the Battery Tender Plus I bought for around $39 dollars at AutoZone a few years back. It works great and the one feature that sold me on it was the quick release/connect 'harness'. You connect the harness to the battery and leave it there and plug it into the tender when you want/need to. I have a battery cover, so the harness eliminates the need to remove it every time I want to connect the tender and it tucks nicely under the lip near the firewall when not in use. :cheers:
P.S. - it does also comes with the clamps like those pictured below. |
I like this Black and Decker from Amazon because it comes with all three connection adapters...$ 20.
https://cimg0.ibsrv.net/gimg/www.cor...82adabb227.jpg |
I use this one,,,, and its a maintainer not a tender ,,,that's the key word..lol
its a little pricy but Digital 400 12V PERFORMANCE CHARGER and BATTERY MAINTAINER Looking for a car, marine, motorcycle, or other AGM battery charger? The OPTIMA Chargers Digital 400 12V Performance Maintainer and Battery Charger automatically maximizes battery life and performance with a built-in battery health mode. It also offers a hybrid LED battery-charging gauge with LCD screen and a quick-set battery type selection for easy operation. And because it recovers discharged batteries that others cannot, this is the maintainer that is a must-have in your garage https://cimg5.ibsrv.net/gimg/www.cor...29f3da1cea.jpg |
Another vote for the battery tender plus. I have had great results
Originally Posted by Welker1
(Post 1593654687)
Another vote for Battery Tender Plus. I'm pretty sure it still comes with a 10 year warranty.
Yes and yes to your above questions. :cheers: Use the O rings that are supplied with the tender to hard wire it right to the battery. |
OK, dumb question time.
What's the difference between a charger, a tender, a maintainer, and a "maximizer"? Not what's written on the box, what do they actually do? I've got an old Sears 10amp "automatic" charger that bulk charges at 5 - 10amps depending on how dead the battery is, then reduces amps to 0 as the battery becomes fully charged. If it's left connected, it will periodically pulse the battery with a small current of less than 1amp. What would it be called today? |
Originally Posted by 05c6silververt
(Post 1593655706)
And do you leave the battery connected to the car when the tender is plugged in? Can the tender remain plugged in for longer term storage, say two or three months at a time?
Originally Posted by wjnjr
(Post 1593655836)
I leave my Battery tender on the car for at least 6 month every year. Never had a problem.
Ok. great! That was quick and painless. Think I'll head over to AutoZone tonight and pick up the BTP. Thanks to all for the quick replies and valuable info.
1 Attachment(s)
If you are going to hard wire it, here's a little tip. The nut that holds the clamp on the battery post is cone shaped. As you tighten down on it, it's job is to pull the clamp tighter. When you go to hard wire the battery tender, tighten down the battery clamp nut and then put the o-ring on top of the nut. Then put another nut on top of that to hold the o-ring in place.
If you un-screw the nut that's on there, put the o-ring on and use that nut you will defeat the purpose of the nut. Another thing, you don't want to drop or lose that cone shaped nut. Here's a photo from my car of the negative side. Hope this helps. |
Originally Posted by Rich Mickol
(Post 1593655918)
I just purchased some float chargers from Harbor Freight for $9/ea.
I have one on the Corvette now and 3 others on my motorcycles. |
Originally Posted by ptroxx
(Post 1593654780)
Originally Posted by windyC6
(Post 1593656273)
And for all practical purposes...the difference between a tender and a maintainer is ??? Does one "tend" while the other just "maintains"....or vice-versa ?? inquiring minds want to know....:flag:
I have 3 tenders. The Corvette branded Ctek that came with my Corvette. The same Black and Decker unit cclive posted above and a Battery Tender Jr. All hooked up to various different vehicles. All work just fine. |
tender
I have the Battery Tender Plus (recommended by Deltran) and leave it hooked up except when using the car. Deltran was aware that some C6's are bad for battery drain and recommended the 1.25A unit over the Jr.
I made a small quick connect harness that comes out near the base of the drivers side windshield wiper and connects to a ceiling mounted retractable cord. Hard to forget to disconnect and right in front of you. Dead battery problems solved. |
Originally Posted by Homer3D
(Post 1593661083)
Maintainer, tender, float…all the same thing. Just different words. I looked up the OPTIMA Chargers Digital 400. OMG. Why pay over $100 for something that can do the job for $20?!?
I have 3 tenders. The Corvette branded Ctek that came with my Corvette. The same Black and Decker unit cclive posted above and a Battery Tender Jr. All hooked up to various different vehicles. All work just fine. I also have the b&d one cc has and another older one. But I do like the way the Optima unit works and displayed everything nice and clear. |
