Handling Those C1 Corvette Hardtops
https://www.corvetteforum.com/wp-con...-rear-view.jpg
The owner of a ’56 Corvette recalls the difficulties of the early hardtops. Read the rest on the Corvette Forum homepage. >> |
2 Attachment(s)
Originally Posted by Detroit Steel
(Post 1593858518)
The owner of a ’56 Corvette recalls the difficulties of the early hardtops. Read the rest on the Corvette Forum homepage. >> In a recent Super Chevy report, writer Brain Brennan details the technique he used to remove the top on his 1956 Corvette. He affectionately describes the process as the “clean and jerk.” It involved placing a blanket across the body of the car, then sliding the top back from the rear. Then reaching across from side-to-side and lifting. Bill |
There are two problems with a removable hardtop. One is getting it on and off the car, and the other is storing it. They take up space and could easily be damaged.
Here is a YouTube video of my design for a home built electric hoist and jig that stores the hardtop near the ceiling and makes installation and removal an easy one-person job. Its not a Corvette, but it is applicable. |
I used to get into the car and lift it with my shoulders and walk it out the door. Haven't used the hardtop in years but would probably use a hoist now.
C3 hardtops with the sharp pins on the rear of the hardtop are the ones that are extremely hard for one person to remove. seats come out easy on a c1 and give you an area to stand and move. if you cannot get the top moved correctly the first attempt the seal in back will allow you to put the top on the deck of the car. that is not the case with the c3, where you get just one shot because of the pins. try just pushing the seats forward in a c3 and trying to move in the area behind the seat.
I never took the seats out when removing the top but the didn't have the pins to deal with. Had to be careful where the brackets attached just behind the doors. Putting it back on was a little more tedious.
