I've changed so many batteries in my life, it amazing Phil that you have not......
Always being a do it yourselfer, I had to replace the battery in my 85 Coupe one time and had a most difficult time prying the battery up out of the hole it seemed to be sitting in nearly destroying it. Having related the story to the guy selling me the new one, he looked it up and said I only had to remove a couple screws holding the exterior body panel on behind the front wheel. The battery slipped right in. I didn't have to use my crow bar and three pound hammer after all. :confused2:
Originally Posted by Mufflerbearing
(Post 1594301832)
Originally Posted by NW94Z
(Post 1594304941)
You've described the process to remove the battery on a C6 Z06 Prying it out of the hole, except there is no body panel to remove to improve access.
Be nice, Joe. He's my age. Sometimes the war stories and memories are too old to recall in vivid detail, or should I say they often ARE remembered in vivid - if not actual - detail? You know, like the adage, "The older I get, the faster I was" You'll find out if you don't soon change your lifestyle. |
I'm currently using a 7lb Harley Davidson motorcycle battery :thumbs: It will crank, and crank, and crank a 2000cc Harley all day. I do take it out, if the car is parked for 3 or more days. It sits on a trickle charger in the garage. It cranks over my LS1 for almost a full minute before it starts boiling :lol:
Originally Posted by ErikwithAK01
(Post 1594307025)
Hey Phil, you know we don't like it (hate) when people start a project, ask for help, and then don't post the results or finish. :smash::smash:
Didn't see one here, did I miss it? Can't believe you haven't seen one of these if you been working on boats. All you have to do is figure out what end goes on the + and what end goes on the - of the battery. Operates like one of those Chinese finger grabber thing'es Can save the back, and the shirt sleeves from disappearing when the acid catches up with them:D Then of course you have to put the battery in so the + & - will attach to the right connectors. :thumbs: You also have to keep the battery from hanging up on the install so one end doesn't have and unanticipated release before seated. I think it's called premature release. Not as in some other things you might have experienced in your Youth.:woohoo: https://cimg9.ibsrv.net/gimg/www.cor...60c6f9a135.jpg Battery Strap |
Originally Posted by NOWUCME
(Post 1594391052)
Didn't see one here, did I miss it? Can't believe you haven't seen one of these if you been working on boats. All you have to do is figure out what end goes on the + and what end goes on the - of the battery. Operates like one of those Chinese finger grabber thing'es Can save the back, and the shirt sleeves from disappearing when the acid catches up with them:D Then of course you have to put the battery in so the + & - will attach to the right connectors. :thumbs: You also have to keep the battery from hanging up on the install so one end doesn't have and unanticipated release before seated. I think it's called premature release. Not as in some other things you might have experienced in your Youth.:woohoo: https://cimg9.ibsrv.net/gimg/www.cor...60c6f9a135.jpg Battery Strap Frankly I've been hesitant to finish the story, possibly out of some embarrassment (he admits as he slaps his hand against his forehead while yelling, "Doh!"). I managed to get the car started and headed directly to the local Les Schwab after confirming they had the right battery in stock. When I arrived, i left the car running and ran inside to see how long it was going to take. They said 2 hours as they were pretty busy so I ran back out to shut off he car, rolling the window down to make sure I could get back in if the battery went dead. It did, as I discovered when it started to rain, and dashed outside to close the window. Owing to the familiarity I've gained in over 10 years of ownership, I reached inside and pulled the lever next to the seat and immediately set off the alarm. Of course I'd given them my key fob as I gave them the order for the new battery so had to chase the right person down to retrieve that. Got the alarm to shut off and returned the fob, neglecting to roll the window back up A while later I was asked to bring my car down to the last stall. This time I remembered to ask for the key fob and went outside, but the door would not open (again) So I pulled the lever and managed to set off the alarm again. Having the fob in hand, I turned the alarm off after fumbling with every button on the fob at last twice and with force. Got in and to start the engine. Nada, nothing but a few click sounds. So out they roll the "jump cart" attached the clamps to the battery. I push the starter button and, nothing... except for some more clicking noises. I continued to push the starter a few times and it finally connected and the engine started. Man, that battery - ex battery - must really be bereft of any form of life whatsoever. Setting off the alarm twice already must have been the final gasp. But I was able to get the car down to he designated stall. My butt was wet from the rain on the sat, but I elected to tough it out in order to watch the technician so I could understand the mysteries of replacing the battery. Turns out it was as simple as many of you told me it would be. The retaining "bracket" turned out to be a simple block secured by a screw. The cables simply "popped off" after removing the cable covers. The new battery went right in, the cables reattached, the covers snapped back into place and that was it. I didn't even have time to slap myself on the forehead. I quickly paid the bill, thanked the tech, waved to all the customers in the waiting area who had been watching this one-man circus while eating free popcorn and drove straight to put the car back in the garage. Fast forward to the next morning. The door wouldn't open. I assumed the new battery had gone dead overnight, probably owing to some drain that was the culprit in the first place. Fortunately I reached down through the open window, set off the alarm, and tried to start the engine. Nothing, NADA... Doh!! Then I noticed the DIC flashing. "No Key Fob Detected Stupid!" (I added the "stupid" myself as that was what was flashing through my brain, but you were probably thinking that anyway as you read this) I ran back in the house, grabbed the spare fob, shut off the alarm, climbed into the still damp drivers seat and started the engine.... Now, what is the probability, I ask you, of the battery in the car going dead at the same time as the battery in the key fob? Oh, by the way I also managed to find in the owner's manual the proper procedure to open the doors when the battery is dead. So no need to tell me now what I was doing wrong (among other things). Oh, I should also mention that removing the batteries from a hydroplane is a lot more simple, even though one has to remove the seat to gain access to them, and hydroplane seats tend to get wet too, even when it's not raining so the process, as I know now, was not completely unfamiliar to me. How personally embarrassing, but you asked and I responded. Glad you didn't ask me for the time of day: I probably would have explained to you how to build a watch. Go easy on me. I'm not a young guy anymore... :leaving: |
Too funny! I have had similar bad days, seems like whatever I do, it just goes bass ackward, and the harder you try, the worse it gets!
(Post 1594391052)
Originally Posted by last901
(Post 1594395395)
Guilty as charged...
:leaving: Don't forget the little charger $20-25 on Amazon delivered to your door. Won't stop the alarm from going off but will help with starting, if you have the fob...and remember you can put the fob in the glove box if needed.:thumbs: |
Phil:
Bought my vette 3 years ago and it has a Costco battery in it. Very happy but then again I have a float charger on it when not driving for a week or two. Note: I have float chargers in my boat for my dual batteries...causes the batteries to last 9-10 years instead of 3-4 for my fellow boaters on my dock (in Chelan, of course). Phil...Chelan comment was for your entertainment! |
