Oil Pressure Switch Location
My 91 ZR1 just sprang a large leak of oil the other day and suspect the oil pressure switch has gone bad I am hearing. Where is it located on the LT5 and how to get too? Thanks for your help!
:flag: |
http://zr1.net/forum/showthread.php?t=24435
Scroll down the page- there is a picture of what you are asking about. |
As Bill suggests :thumbs:
OIL PRESSURE Oil Temperature Sensor Wiring (Dash/ECM) TIPS Gauge Oil Pressure Sensor Calibration TIPS Removing Oil Pressure Switch TIPS Oil Pressure Sensors TIPS Engine Oil Pressure/Temperature Sensors TIPS Oil pressure sensor location Low oil pressure Oil pressure switch removal Sensor Oil leak Mechanical oil pressure gauge Oil Filter Adapter Sensors ........................................ ......Oil Filter Adapter Ports and Sensors http://i287.photobucket.com/albums/l...ps4cacf14a.jpghttp://i287.photobucket.com/albums/l...136a877a75.jpg LUBRICATION Post 18 - Engine Lubrication System Functional Discussion Post 19 - LT5 Lubrication Tricks Post 20 - Potential Oil Leaks and the OPRV Cover Plate |
Originally Posted by TealZR1
(Post 1594606932)
:flag: https://cimg4.ibsrv.net/gimg/www.cor...1349fe839c.jpg |
My heart goes out to you. Check my thread "oil overfill effects". My issue was indeed the oil pressure switch. It's a bear to get to without pulling the the oil filter housing, but it can be done. Stay patient and it will go another 25 years without issue!
switch
Originally Posted by jss06c6
(Post 1594608154)
I suggest going to the parts store and getting the special socket that make for the sensor. You can put a box end wrench on it. https://www.summitracing.com/int/par...srese1-_-lisle |
(Post 1594606932)
:flag: When it fails, the oil leak is always sudden and significant. |
switch
Originally Posted by A26B
(Post 1594610279)
BEFORE REPLACING the Switch, you can tell if it's the Oil Pressure Switch by unplugging the Connector to the Switch. When the Switch is the source of the oil leak, it's always through the Switch & the Connector will be oily.
When it fails, the oil leak is always sudden and significant. that is exactly what mine did. great advice |
