Need a Memcal/Calpak
I need to find a spare Memcal/Calpak so I can have a custom chip burned.
Does anyone have one that they would sell me? Here is a picture of the stock chip in my 87. Do I have to get one with the same "abtf" code? Any tips/pointers will also be appreciated. Thanks! http://my.execpc.com/~dfilo/87chip.jpg |
Re: Need a Memcal/Calpak (Hole-Shot)
I have been going through the same thing but found some part #'s.
I believe the part # for your 87 EPROM is: 16070733 This is for an 87, A-Trans, 3.07 rear Try GMpartsdirect.com, I plugged in the number and it came up around 30 bucks. HTH, Mark |
Re: Need a Memcal/Calpak (Mark84_L383)
I have been going through the same thing but found some part #'s.I believe the part # for your 87 EPROM is: 16070733 This is for an 87, A-Trans, 3.07 rear Try GMpartsdirect.com, I plugged in the number and it came up around 30 bucks. HTH, Mark Still would like to find a used one if possible. BTW, Nice looking motor! :cool: Have you ever ran it in the 1/4 mile? [Modified by Hole-Shot, 2:17 PM 9/28/2002] |
David are you looking for a used EPROM to have burned?
Give Jeff Kopp a call. I dont think they are very expensive.
http://www.superchevyperformance.com/about.html |
Re: Need a Memcal/Calpak (Muffin)
David are you looking for a used EPROM to have burned? |
Found a supply of used ones last week. e-mail me your requirements.
________________________________________ _______________
Quote: BTW, Nice looking motor! Have you ever ran it in the 1/4 mile? ________________________________________ _______________ Did last night, new to drag racing so my Reaction Time is slow and I'm on street tires; 12.77 sec/114.8 MPH (1.18 sec RT) was my best. |
GM P# for an 87 Vette MemCal 16070312
The EPROM does not have to match, by the MemCal needs to be correct for the engine/trans combo. There is a ResPack that tells the ECM what engine/trans/rear gears it is working with. Just don't expect to us a V6 MemCal in a V8 application. All bets are off that it will not show a problem. |
