MAP sensor help for C6Z
Hey guys, looking for some map sensor advice for my 2008 c6z.
just finished build and I'm wondering what map sensor to use. will a zr1 3 bar work? what are you guys using? Thanks! |
2 bar cobalt or 2.5 bar Dsx are simplest. Zr1 can work but have to change the plug and I believe you have to drill the hole on the manifold out slightly so it'll fit
Originally Posted by schpenxel
(Post 1594740608)
I have a 2.5 bar one I made if you want it for cheap. It's not pretty but it works. I made it myself, same sensor as DSX uses. I hated how it looked so I switched to a Cobalt 2 bar sensor since I'm not going over 15psi
You should be able to find an adapter for the MAP connector if you want to use ZR1--that's probably what I'd do. Just google ZR1 MAP adapter or something like that and you should fine one |
Easy enough to use a ZR1 map.
Originally Posted by Intense.
(Post 1594740338)
just finished a turbo build and I'm wondering what map sensor to use. will a zr1 3 bar work? what are you guys using? Thanks! |
ZR1 MAP part number is 12592525
You can get them pretty much anywhere. Amazon, ebay, summit, any GM parts place, etc. |
Originally Posted by darkknight91
(Post 1594744109)
Talk to Gene Culley he can help you locate a zr1 map sensor.... he's the man around here.
I'm working on sourcing cores.
If Dave can find cores and make you one it's the way to go. Direct replacement and works perfectly.
Thanks for the help guys. Ended up buying the ZR1 map fro the dealer along with the connector.
I forget, but certain years/ecus can't take the zr1 map values in the ecu, so that presents an issue.
I think that's mainly 05's but don't have stock tunes on work computer so I can't check. But the earlier models are weird so it may be these too
That was the reason I didn't do a 3 bar, because I thought my ECU can't take the values. I'm pegging the 2.5 bar now, not a big deal, runs fine, but would be nice.
Originally Posted by Unreal
(Post 1594756370)
Yes
I think HP Tuners only support 2.5 bar for the later ECUs. Gen 3 (us c5 peoples) can do the 2 or 3 bar though.
Using virtual VE gen 4 guys can go as high as they want. Or at least until the map sensor maxes out.
(Post 1594744109)
The LS9 map sensor (12592525 is the part number) is great if you can easily swap the connector or get an adapter harness. You do have to drill out the hole in the intake manifold as the nipple on the sensor is larger.
The custom ones I make are expensive, take a lot of time, and are a pita to make... but they're true plug and play. 05 C6s are the only rough one because the operating system itself won't accept the linear scaling value of the LS9 sensor. |
