I take it an oil cooler didn't solve overheating?
Somewhere, someone along the way must have tried a dedicated, separate oil cooler for our cars, right? I'm aware of the aux cooler added to the M7 models, but don't actually know if it removes the water-oil exchanger or not (I assume not).
You'd imagine that if you could find airflow for it, removing the entire engine oil heat load from the coolant (since it's just in the little block-mounted exchanger from the factory) should take a LOT of load off the cooling system, especially once oil temp gets >250. What was the result though? Too hard to fit, so no one ran a test that way, or didn't make enough of a difference when it WAS tested? |
Originally Posted by DAVE396LT1
(Post 1594831550)
You'd imagine that if you could find airflow for it, removing the entire engine oil heat load from the coolant (since it's just in the little block-mounted exchanger from the factory) should take a LOT of load off the cooling system, especially once oil temp gets >250. What was the result though? Too hard to fit, so no one ran a test that way, or didn't make enough of a difference when it WAS tested? There is now a temperature controlled bypass that opens up at 177dF iirc that replaces the 'brick''; why this hasn't been paired with a dedicated setrab etc. oil cooler surprises me, although getting airflow to a dedicated oil cooler remains a challenge. Bish |
(Post 1594831550)
You'd imagine that if you could find airflow for it, removing the entire engine oil heat load from the coolant (since it's just in the little block-mounted exchanger from the factory) should take a LOT of load off the cooling system, especially once oil temp gets >250. What was the result though? Too hard to fit, so no one ran a test that way, or didn't make enough of a difference when it WAS tested? The only way to bleed off all the heat involves opening the car's nose to additional radiators. |
(Post 1594831550)
You'd imagine that if you could find airflow for it, removing the entire engine oil heat load from the coolant (since it's just in the little block-mounted exchanger from the factory) should take a LOT of load off the cooling system, especially once oil temp gets >250. What was the result though? Too hard to fit, so no one ran a test that way, or didn't make enough of a difference when it WAS tested? The aux cooler is just a secondary radiator and still uses coolant to cool the oil. We are working with DeWitts to finish up an oil cooler kit for the C7 using our thermostatic oil cooler adapter and their cooler. It should be available both from us or DeWitts. |
When GM created the overheating problem with their second generation Duramax diesel a number of owners (and firms) tried to solve it with a large oil cooler. The Dmax also uses a oil to coolant exchanger. But the additional cooler helped very little and the only approach that worked was a large secondary radiator. Unlike the C7 there was plenty of room and airflow for the pickup but it is a history repeats itself moment when once again a platform had been released with insufficient cooling capacity for its rated (and highly advertised) capabilities.
Originally Posted by HighBeta
(Post 1594832163)
Dewitts makes a dedicated outboard oil cooler to go along with their radiator and intercooler upgrades. When tested as a package, it made a "significant" difference, but still unable to dissipate *all* the heat generated. Search for the very informative thread from GSpeed.
When you remove the oil cooler from the cooling system, and you're able to keep the oil temps below 275, the net cooling gain is roughly 15-20*.
If you leave the oil cooler in the cooling system, you are adding that heat load into the cooling system, which cannot work hard enough to keep coolant temps in check, even with added radiators. We ran the OEM oil cooler and with the stage 2 system we offer (70mm dewitts, and 50% secondary radiator) and coolant temps were reaching 240, with oil temps over 300. Please see post 164 of our cooling thread from 1 year ago, last summer: https://www.corvetteforum.com/forums...post1592637335 |
Originally Posted by johnglenntwo
(Post 1594832351)
https://www.corvetteforum.com/forums...ooler-kit.html
https://cimg5.ibsrv.net/gimg/www.cor...f88fa0dfd5.jpg http://store.katechengines.com/mobil...-kit-p551.aspx |
Originally Posted by Warp Factor
(Post 1594838444)
That just puts an additional heat burden on the engine coolant system, which is already inadequate.
It's best to increase coolant capacity of the radiator by upgrading it and adding secondary radiators while also removing the burden of oil cooling from it by running a separate air-to-oil cooler. |
It certainly doesn't meet the OPs original constraints which are impossible!
(Post 1594838444)
The significance thereof? Even the vendor seems undecided.:thumbs: |
Originally Posted by ImprovedRacing
(Post 1594832167)
In addition, I am working on a new kit that will package two air/oil heat exchangers in the same area as the A8 or GMPP add on cooler. One cooler for ATF and one for Engine Oil. This design will allow Z06/A8 cars to completely remove the engine oil heat by eliminating the brick cooler and exhausting this heat below the car. The connections for the A8 ATF will be the identical size and location as the factory for plug and play installation. We may expand this offering with a M7 version, with the 1st section used as an EOC and the 2nd second used for an "add on coolant" heat exchanger. In both cases the horizontal mounted H.E. is upgraded from 26mm to 46mm thick. Minor plastic trimming will be required to allow for this increase in thickness. I expect to release this design sometime in July so it will be just in time for those hot summer days. https://cimg5.ibsrv.net/gimg/www.cor...74fda25040.jpg |
(Post 1594839030)
Your word "additional" is incorrect though.
Thanks!
Originally Posted by Tom DeWitt
(Post 1594839277)
We are really excited to team up with IR with our cooling components. Some customers that race and drive their cars in the north have said the oil cooler works a little too well and the addition of a IR adapter would fix that.
Lets see!? ;)
(Post 1594839459)
If it cools the oil better, where do you think that extra heat removed from the oil going????
1.) The new air stream outs the back. But, that air stream is HOT! And like the vender said it's omitted by the move, most significantly! But, yes - where's the data!?:toetap: |
we use/sell the prospeed oil cooler kit on our c7z customers and c7 customers that road race. works wonders and fits amazing.
Okay, is the brake cooling symmetrical?
Originally Posted by Joe@CPR
(Post 1594839650)
sub'd
(Post 1594839650)
We wanted to create a package that : 1. Removed the Engine oil heat from the coolant (Delete Brick) 2. Exhaust the above heat without going through the HX or radiator 3. Did not require removing or altering the front fascia 4. Use the same factory lines for TOC (A8) 5. Mount in existing A8 TOC bolt pattern (Or GMPP) 6. Affordable pricing I feel this new system accomplishes all the above requirements. |
(Post 1594839950)
Joe, that is a nice system. It takes the engine oil heat off the coolant system and exhausts it out through the wheel well and that was part (#1 and #2) of the criteria behind our new design.
