Great job new cam from Horsepower Addicts in DE
1 Attachment(s)
Coming off an off ramp in my 05 I stepped into it and heard what we all dread.....KNOCKING....followed by a check engine. Was a cam sensor code and misfire. When i pulled the cam sensor it was torn up by something. Had a feeling it was the dreaded LS2 cam crank bolts loosening. Called a few shops in the area (PA) and Josh was the most responsive and the only one I felt who was truly giving me the time to review. Had the car send to Horse Power Addicts in DE, where josh and team confirmed the cam crank bolts (all three) had loosened up, cracked the cover but the chain was intact. One bolt was sheared off! This is the point I consider myself very lucky.....discussed w/ Josh the options and luckily after pulling the pan Josh found the bolt head AND cam pin in the oil pan. Next, he pulled the cam and found some marks on the lobes and let me know they probably touched the lifters. Made a decision to pull the heads, and good decision as number of lifters had been flattened on the top side. Josh checked the heads and pistons and all checked out good (again, lucky)
ive been to enough corporate events to know when you have lemons...make lemonade....so reviewed with josh and decided to upgrade all that was already apart to: Dewitt Radiator Cam gear GM chain and chain guide LS7 Lifters and new trays BTR springs and pushrods 160 stat Texas Speed Torquer V2 232 234 .600/.600 113 lsa Car already had kooks headers, kooks mid pipe and corsa extreme. Dyno was 442 RWHP and 407 RWTQ Josh tuned the car perfectly and it has great street manners and comes to life when you put your foot into Working with Josh was great to deal with always answering my questions and letting me know my options for what I was looking for. He sent pics along the way to show me what happened each step of the way He also changed little things the car needed(motor mount and gaskets where needed, etc) and worked out a price that was reasonable and started/finished the work when he said he would (plus no tax in DE). I highly recommend Josh and the Horse Power Addicts Team. Quick vid at idle with new cam Pic of broken cam bolt |
it doesn't make any sense? the lobes of the cam DO touch the rollers of the lifters, the cam is held in place by a retainer plate it can't walk back and forth no matter what the cam bolts, timing sprockets do. seems like you at least go with a C5 race chain and obviously there was something else going on for "lifters being flattened on top" whatever that's supposed to mean?
Glad your happy with everything Evan. You caught the issue just in time. :thumbs:
Originally Posted by CMY SIX
(Post 1595173399)
Originally Posted by edean
(Post 1595172750)
ive been to enough corporate events to know when you have lemons...make lemonade....so reviewed with josh and decided to upgrade all that was already apart to: Dewitt Radiator Cam gear GM chain and chain guide LS7 Lifters and new trays BTR springs and pushrods 160 stat Texas Speed Torquer V2 232 234 .600/.600 113 lsa Car already had kooks headers, kooks mid pipe and corsa extreme. Dyno was 442 RWHP and 407 RWTQ Josh tuned the car perfectly and it has great street manners and comes to life when you put your foot into Working with Josh was great to deal with always answering my questions and letting me know my options for what I was looking for. He sent pics along the way to show me what happened each step of the way He also changed little things the car needed(motor mount and gaskets where needed, etc) and worked out a price that was reasonable and started/finished the work when he said he would (plus no tax in DE). I highly recommend Josh and the Horse Power Addicts Team. Quick vid at idle with new cam https://www.youtube.com/watch?v=9xE74ltiZ4Y Pic of broken cam bolt :iagree: I also had a great experience with Josh but it was when my daily driver lost it's clutch and they took me in asap and had the work completed within less than a week! Josh explained what was wrong with the car and gave me all the options needed to fix the problem. Highly recommend these guys!!!! |
