Replaced PCM now car wont crank
I purchased a PCM from the salvage yard for my 2006 Z06. The PCM I purchased is a 12597121 which differs from the PCM in the car. I had my tuner unlock and transfer my tune with HP Tuners, but when I put it in the car will not crank. Am I missing a step?
Thank you |
There's a security "relearn" procedure IIRC.
Gotta do a clutch relearn. Need a scanner to do it.
Originally Posted by MTPZ06
(Post 1595243165)
Originally Posted by Josh Dockstader
(Post 1595243246)
MTPZ06 is this something that can be done without a scanner? Do you have a link to the procedure? Thank you
When drivers door is open does the security light on dash flash, off or stay solid on ? If its not flashing then the PCM and the BCM need to relearn and sync up that security code This is a security relarn proceedure...but this may not be your issue. You may wind up needing a scanner. Turn ON the ignition leaving the engine OFF for 11 minutes. Turn OFF the ignition for 30 seconds. Turn ON the ignition leaving the engine OFF for 11 minutes. Turn OFF the ignition for 30 seconds. Turn ON the ignition leaving the engine OFF for 11 minutes or until DTC P1630 sets. Turn OFF the ignition for 30 seconds. Turn ON the ignition leaving the engine OFF and wait 30 seconds. Attempt to start the engine. If the engine does not start, Refer to the Powertrain On Board Diagnostic (OBD) System Check in Engine Controls. Important: Performing this procedure may cause a DTC P1630 to set. If a DTC P1630 sets, turn OFF the ignition for 30 seconds, then turn ON the ignition. If the DTC P1630 does not clear, Refer to Powertrain On Board Diagnostic (OBD) System Check in Engine Controls. |
(Post 1595243468)
Do you know if your tuner did a vin flash as well?
Securty relearn did the job! Thank you guys!
[QUOTE=Josh Dockstader;1595243970]Securty relearn did the job! Thank you guys![/QUOTE
Great to have CF members who take the time to share their expertise. Nicely done! |
[QUOTE=Vernon;1595243998]
(Post 1595243970)
Awesome say it who's your daddy lol MTP.
MTP, even if you were wrong, just typing in that post deserves some kind of recognition.
You done well, very well, and you were correct. |
Don't forget to perform a case learn.
Why'd you change the ECM in the first place? |
Originally Posted by Mike44665
(Post 1595255704)
You done well, very well, and you were correct. Looks like he's on the right track though. |
Originally Posted by Michael_D
(Post 1595258058)
