Modified LED Tails w/Halo
Greetings - Any thoughts or ideas would be appreciated. I installed new LED tails, modified with the halos. My wife was following me the other day and noticed the halo in one of the tails fails to light. She also thought two of the lights were a bit less bright than the other two. I'm going to check connections but again, any thoughts on what my problem may be?
Thanks! |
If you installed NEW units, I'd suggest sending them back and asking for replacements. I had one arrive DOA and the vendor sent a replacement that same day. I'm not sure you want to try to disassemble these things, and risk damaging them if you have other recourse.
Make sure that you have them wired the right way. LED's only work with the right polarity.
Originally Posted by coia96vette
(Post 1595334287)
Originally Posted by mrmagloo
(Post 1595334260)
(Post 1595334260)
I agree with the others. If you just bought them new, the vendor will likely replace the defective taillight. I would contact the vendor.
:iagree:Contact Vendor!
Another thought, put the OEM lights back in. Mine work perfect after 15 years!
Originally Posted by c5BlackBeauty
(Post 1595334151)
Thanks! |
Originally Posted by DDaaryl
(Post 1595340106)
I bought 2 sets at that time and have the second set still in the box unused :D |
1 Attachment(s)
(Post 1595340106)
i have modded halo also and my right inner goes completely off when the brake is pressed. the parking lights on halos work as should. i wonder whats the warranty on these?
Same here.
Originally Posted by ri-vette
(Post 1595351804)
fixed!!! i just bent the lil taps in the vechiles harness side. fixed thank god!!
(Post 1595357183)
