TorchRedFred |
09-09-2017 02:36 PM |
You might be better off posting these questions in the C6 general discussion section. I'm not sure about the LED's. With the squeaky top, I have two tops and neither one of them squeaks. I'm not sure why some guys have consistently squeaky top. I want to say to check your handles and latches to see if you can make any adjustments to make them tighter. I notice my handles all seem pretty tight to lock and unlock especially the rear one. The rear lock handle has a small hook that latches to the car that can be adjusted. First you have to loosen a locking screw with an allen wrench and then it looks like you can screw the hook in or out to make it tighter or looser. I'm not sure if that's your problem or not, but it's one more thing you can check.
