Rear hub replacement question
i am replacing the rear hubs on my 93, from the research I've done; I believe I only need the teflon washer and there is no hub seal/dust seal needed. I bought Timken bearings and they did not come with anything besides the assembly. I want to make sure if my car requires a seal I get a new one... but if I don't need it I don't want to waste my time
if it was mine, i'd replace the Teflon washer, there' cheap and should be available at any dealership...Just My Opinion. I have a 93 also...
I recently did my 95. I could not find the teflon washers anywhere. If you can find them replace them while you are there. The bearing is a sealed unit, so no other seal needed. Remember to put some anti sieze on the axle splines.
Gary |
Pay attention to how the old washer comes out, they have a lip that has to go in a certain way...WW
Originally Posted by yd328
(Post 1595668374)
Gary Garry, you read my mind.... I can't find the teflon washer. Dealership says the part is no longer available, my next question was going to be; what's everyone's opinion on reusing the washer? In most videos I've seen it reused and just greased up. |
I would check online for the Teflon bushings, they have to be available somewhere. The hubs I've looked at have had a seal of one form or another. Some were separate while some were incorporated into a groove in the hub. The unit was sealed but apparently it's intended to keep the dust and dirt out of the spindle area. I assume that's what they're for.
In the event you can't find new seals, if it was me I'd grease the old ones before I put them back in. The Teflon has to be in there for a reason. |
They were no where to be found when I did my rear hubs.
I would check online for the Teflon bushings, they have to be available somewhere. The hubs I've looked at have had a seal of one form or another. Some were separate while some were incorporated into a groove in the hub. I never siezed them and put them back in, I had no choice at that point. Maybe keep an eye on ebay. Gary |
I bought an extra set of washers when I heard they were getting hard to find about 4 years ago..I should of bought a few dozen I guess..WW
I did talk to Rydell Chevy today and he stated he could not get the washers
GM# 14076924 but said these 3 dealers still had them and they are around $8.24 for 2 I think. Good Luck Tennessee 865-970-9378 FL 305-556-2777 NY 585-591-2300 |
Check Corvette Central and search 14076924
I got a back order message from CC. They also stated no eta from the manufacturer. That was about a month ago.
Gary |
A few years ago, I ordered two washers. When I did my hubs a couple of years ago, I looked at the old washers, they seemed to be in good shape so I greased both sides of them and re-installed them. The hubs and rear end haven't made any of the noises associated with bad washers. So I would recommend greasing and re-using them.
I'm keeping the new ones on the side for the future (if necessary). :cheers: |
