Water Pump Woes (65-365hp)
Here is my original thread...
https://www.corvetteforum.com/forums...-65-365hp.html I had the original water pump rebuilt locally because I wanted the correct 1/2" bypass. I took the car for a ride and I had a terrible vibration and after 2 miles, the water pump failed and coolant was leaking out. You can move the fan a lot so it must have took out the bearings. I've had a vibration in the motor at higher RPM's that must be related to the pump, pulley or fan. When I replaced the pump I replaced the fan clutch as well. The pulley showed a wobble when it spun like it wasn't sitting correctly on the water pump shaft. Like I said after the rebuild, the vibration was pretty bad. I ordered a new pulley that is almost $300.00 and I think I'll replace the fan as well. I plan on also putting on a replacement water pump and using a bushing for the bypass elbow and then sending the correct one to Bill Mock for another rebuild (he did not do it the first time). I just wanted to share my pain and frustration. Thanks for reading! |
I talked to Bill Mock about rebuilding my pump and come to find out that he used to own my car over 30 years ago! He remembered it well and has a picture of it on his wall that he is going to scan for me. Small world!
Originally Posted by 89vette
(Post 1595929920)
https://www.corvetteforum.com/forums...-65-365hp.html I had the original water pump rebuilt locally because I wanted the correct 1/2" bypass. I took the car for a ride and I had a terrible vibration and after 2 miles, the water pump failed and coolant was leaking out. You can move the fan a lot so it must have took out the bearings. I've had a vibration in the motor at higher RPM's that must be related to the pump, pulley or fan. When I replaced the pump I replaced the fan clutch as well. The pulley showed a wobble when it spun like it wasn't sitting correctly on the water pump shaft. Like I said after the rebuild, the vibration was pretty bad. I ordered a new pulley that is almost $300.00 and I think I'll replace the fan as well. I plan on also putting on a replacement water pump and using a bushing for the bypass elbow and then sending the correct one to Bill Mock for another rebuild (he did not do it the first time). I just wanted to share my pain and frustration. Thanks for reading! :cheers: Gerry |
(Post 1595929920)
https://www.corvetteforum.com/forums...-65-365hp.html I had the original water pump rebuilt locally because I wanted the correct 1/2" bypass. I took the car for a ride and I had a terrible vibration and after 2 miles, the water pump failed and coolant was leaking out. You can move the fan a lot so it must have took out the bearings. I've had a vibration in the motor at higher RPM's that must be related to the pump, pulley or fan. When I replaced the pump I replaced the fan clutch as well. The pulley showed a wobble when it spun like it wasn't sitting correctly on the water pump shaft. Like I said after the rebuild, the vibration was pretty bad. I ordered a new pulley that is almost $300.00 and I think I'll replace the fan as well. I plan on also putting on a replacement water pump and using a bushing for the bypass elbow and then sending the correct one to Bill Mock for another rebuild (he did not do it the first time). I just wanted to share my pain and frustration. Thanks for reading! Just saw your other post, bummer on the pump but, your pulley may still be fine. |
(Post 1595929920)
Yes I will check the alignment of the old pulley and new pulley before assembly. I ordered a rebuilt pump from Chicago Corvette that is supposedly an unsleeved correct 1/2" NPT undated 326 pump. We will see when I get it.
(Post 1595942268)
hope they had it IN STOCK...... Don |
Supposed to ship today so we will see.
