Harmonic Blancer
How many of you have looked to see if your harmonic balancer is wobbling and if it is how much did you pay to get it fixed
I replaced mine before it started wobbling. The new ATI damper was about 350 bucks. I did the labor myself as part of a cam swap.
Another very good HB ...
Dayco 'PowerBond' Harmonic Balancer P/N: PB1117SS $ 222.97 Shipped https://www.summitracing.com/parts/p...model/corvette Personally, I wouldn't go through all the trouble replacing it until it actually starts to wobble ... Some engines will go forever without a problem, while some balancers will fail early in life (it's a crap shoot). |
And by the way .... If you ever do replace the harmonic balancer, DON'T replace it with another OEM balancer.
Unless GM is replaceing it for free |
Originally Posted by Garry in AZ
(Post 1596110142)
I replaced mine before it started wobbling. The new ATI damper was about 350 bucks. I did the labor myself as part of a cam swap. That would be a good time to replace the HB with a quality aftermarket HB. The HB has to be removed anyway in order to replace the camshaft. |
I'm looking at a C6 to purchase. How do you know if the HB is wobbling? And to add to my stupidity...where is it??
Mine is wobbling a little. (Relative term). I'm under warranty but don't know if they will replace it simply because it's wobbling. However if I wait for it to cause major damage (assuming it will someday) then they will have to replace much more than the HB.
Not to hijack the OP's thread but has anybody had it replaced under warranty simply because it wobbles a bit? I'm sure many techs would simply say "yeah, they all do that!" Also if they do replace it can I upgrade to a better aftermarket unit and pay the difference? |
Originally Posted by Ramets
(Post 1596110702)
Originally Posted by danzio56
(Post 1596110713)
Flashlight under the hood looking down from drivers side. If looking straight on from the front end the HB is located about 8 o'clock (for reference).
(Post 1596110713)
If it's wobbling, you'll see it. I paid $250 for the TrickFlow balancer with Continental belts and a $10 GM crank bolt. I paid ~$800 for installation :( |
Originally Posted by Turbo6TA
(Post 1596110294)
Dayco 'PowerBond' Harmonic Balancer P/N: PB1117SS $ 222.97 Shipped https://www.summitracing.com/parts/p...model/corvette Personally, I wouldn't go through all the trouble replacing it until it actually starts to wobble ... Some engines will go forever without a problem, while some balancers will fail early in life (it's a crap shoot). So I bought mine from Rock Auto, little more pricey but it was perfect, FYI I'm sure it has been corrected by now as this was about 4 months ago NSF |
We DIY'd this one:
CHEVROLET CORVETTE Summit Racing® Bracket Racer SFI Harmonic Dampers SUM-C2501 189.97 So far (3 years) no problems. |
Originally Posted by jaredtxrx
(Post 1596111281)
Passenger side gives a much clearer view.
Chevy replaced mine under warranty. The invoice states it was ~ $1200.00. It probably cost them < $200 in parts/labor.
Originally Posted by CMY SIX
(Post 1596111906)
when you bent over for that, I hope they at least used a little lube.
Originally Posted by windyC6
(Post 1596112966)
Yep....unfortunate, but that seems to be about the going rate for the R&R at a the stealer ship.
(Post 1596111281)
( Maybe what I'm thinking is the HB is clearly some other pulley and my HB is completely wobble free, as anything I see from the passenger side is running true. It is only the lower left pulley only visible from my drivers side that wobbles. If it isn't the HB then what is it? |
I have a powerbond 25% Underdrive for sale PBU1117SS25 like new. Will for the GS auto and the base C6 wet sump. Will not fit the GS 6-speed dry sump. $160 shipped
Originally Posted by Jack Forbes
(Post 1596110033)
