Bose Speakers
1992 Corvette coupe original Bose system passenger side speakers work but Drivers side both front & rear not working ?
Probably amps. Buy a front and see if it corrects it, if so then buy a rear. Got a front from a guy here that sells on E-bay for $35 or so shipped.
In addition to Ebay, scour Craigs List. There are often guys parting out C4 and the amps are cheap.
Do you want to be 100% original? If not, you can run separate wires for the newer and better systems that have bluetooth, XM radio, CD Changers, etc, etc instead of that crappy old thing.
Originally Posted by aklim
(Post 1596396309)
Originally Posted by Gmorrison
(Post 1596396388)
I just bought this off I gentleman that kept it in show condition and only has 38,000 miles, was leaning to keep original but the more I learn about the Bose systems back then the more I'm starteing to think I'd be money ahead to switch out !
(Post 1596396388)
Or you can do the right thing.....
https://www.corvetteforum.com/forums...inc-in-fl.html Your choice. Skiddy |
(Post 1596394956)
Do you hear anything, static or sound coming out of the defective side speakers. If it is a speaker box, the amps may be able to be repaired as I have fixed many. If the CDM is bad, all I could say about is give it a good visual inspection for leaky capacitors. Other than that it would have to be sent out for repair. Do what you got to do, my Bose system is so clean and the sound is excellent. I'm not a big Bose fan but they had some really good technology. But it's not a high tech system as some of the newer systems with additional features. But I wanted to stay stock and as long as I can support it I'm happy, a personal preference. |
(Post 1596396309)
Crappy old thing, Bose Gold sounds great !!!! :lurk: |
Originally Posted by Cool Runnings
(Post 1596422752)
I had the same driver side problem in my 96. Do the easy diagnosis and swap sides. From there you have many options. My car turned out to have a CDM problem. Instead of sending out the CDM to be repaired I spent the same amount of money and bought a pioneer head unit and got the wiring adapters to keep the speakers. I didn't want to run any more wiring than I had to so I kept the factory speakers. There is also so much road noise and the interior geometry just isn't made for good sound I didn't want to replace the speakers.
Now, if you swap sides and they work, you have an amp problem most likely. It is possible you have a bad speaker on that driver side so make sure you try both speakers when you swap them to verify your original driver side works. If you have an amp problem you have options again; you can send them out to be repaired or go to a junkyard and try to find a set out of a 90s Infinity. There is a post on here if you search the keywords that details what years and models to look for. I got a set of four at pull a part for like $48 just in case I need amps. If you don't want to mess with amps you can always follow aklim and do the whole darn thing. Ultimately it comes down to originality and how much you want to spend to keep it that way. |
I just replaced all four amps in my 1992 corvette for 10$ piece. it sounds incredible now. the amps were from a 1997 nissan maxima which has the revised and updated versions of our amps.
I might be inclined to let the extra ones go for 25$ a piece shipped locally. |
I kept my car bone stock and I am not sorry. I had the same problem and replaced the amps.
Originally Posted by ccramer
(Post 1596432952)
Dr. Don's
(Post 1596394956)
(Post 1596396309)
(Post 1596432952)
I might be inclined to let the extra ones go for 25$ a piece shipped locally. Please do tell! |
