Dragvette Before and After Pics
https://cimg8.ibsrv.net/gimg/www.cor...0c1a54653.jpegRough beginnings.
https://cimg9.ibsrv.net/gimg/www.cor...bc214ebc0.jpegThis is eyeballed. I’ll let the suspension settle and do a full alignment in the coming weeks. |
Originally Posted by DIY-79
(Post 1596408830)
First part of next week I plan to have the tires off and will get some shots. I did use Van Steele offsets as well as QA1 single adjustable shocks. I haven’t seen any clearance problems but I haven’t done a thorough check. I will say, it’s very easy to change camber. Also, I pulled the c-clips and that helps a lot.
(Post 1596409669)
Gotcha. I’ll do that. Do you have experience with the system or curious based on others comments?
1 Attachment(s)
(Post 1596410519)
Very nice. I’m going to go with the Rival S also. What backaspaing you running. When I pulled the c clips I slipped the side yokes out until I had about an 1/8” still past the spider gears. That allowed about 1/3” of side yoke outside the diff. Should translate to a bit more room. I took a piece of flat steel and drilled a hole in it and I I mount it on the rotor. Then I can spin it around and measure to the frame to get my max BS. I’ve been crunching numbers using specs from Tire Trac to find total backspacing (backspacing of the wheel + overhang of the tire).
I'm curious on if they fixed the upper link to frame clearance issue. I had this on mine one summer and every small dip in the road or bump it sounded like somebody smacked the frame with a hammer. The upper link mount on the arm was hitting the frame. Mine was a little lower than stock but not much. I worked with them for a while but it was just not working. I did use stock arms at the time so you guys with VS off sets should have a different experience than I did. It was a good setup just allowed very little wheel travel. I now run VS coil over setup on all 4 corners.
I know it says in the literature that can be a problem. I was originally going to keep my stock trailing arms but one was cracked length wise so I just forked up the money for new ones. You’ve sparked my interest in this. I’m building a non specific car that I’d like to be respectable in the 1/4 mile as well as turn respectable lap times. Jack of all trades so to speak. I have a 420 lb spring so hopefully it won’t travel that far.
Looks beautiful. Nice work!
Originally Posted by Gordonm
(Post 1596411144)
It is a bad ass setup for drag racing though, and it will keep the wheel in place if you break a u joint... |
Yeah. I’m more focused on straight line. Had a low 11 sexy mustang in my teens. I’m older now and have a conscious and can’t make a Corvette purely a straight line car. So to be a jack of all trades you have to compromise in areas to be average at everything. I felt like the Dragvette would accomplish that for me.
https://cimg2.ibsrv.net/gimg/www.cor...f39b353074.jpgThis is the newer top mount. The outer hiem contacts the frame bump stop mount about 3/8" before full shock travel. I think there are ways to get full shock travel without too much work but Im still deciding on approach.
Do those spring bolts look correct? They look to tight to me. Is that for better handling (to limit suspension travel)? To me that spring looks to be wound to tight.
Originally Posted by Neil B
(Post 1596415858)
I’ll check on this Monday morning. I’m a fire fighter and started a 48 hour shift today. I still need to bleed the brakes and set the shims for toe. |
Originally Posted by bence13_33
(Post 1596415888)
If your talking about my spring bolts, that’s how tight I had to tighten them to get the half shafts to the “Greenwood” recommended angle. They are 8” bolts and will be cut down to almost flush when the ride height is set. |
On a different note, this marks the end of replacing all the bushings in the entire car. I started in the front and replaced upper control arm and lower control arm bushings. All four ball joints, all four tie rod ends, and the idler arm. Front sway bar bushings. Transmission mount, all eight body mounts, and the complete Dragvette rear suspension. The front saw QA1 coilovers and the rear QA1 shocks as well. All single adjust. Even the differential support bushing was changed. The crossmember bushings were the only bushings I left. I have a thread titled “My Sumbrero Fix” were you can see my solution for a stripped nut in a sumbrero. One of mine was stripped via a previous owner. I’ve been undoing a lot of Bubba. I also changed the rear wheel bearings during this project. The goal was a mechanically sound car. Steering column and brake system is next.
The reason I say all that is a lot of the anomalies in how the body sat on the frame were solved by doing this. The suspension in relation to the frame is better off too. Before I had to tighten the rear spring bolts noticeably different lengths to get the half shafts the same angles. I was pleasantly surprised at how close they are now.👍🏻👍🏻
(Post 1596416087)
(Post 1596416196)
Yes that is what I was referring to. It just looked like it was bowed almost to the point of going the opposite direction which is the only reason I raised the question (maybe it's the angle of the photo). Interesting.
It’s very close. It’s something I too am concerned about. The tighter the bolts are screwed the flatter the spring became. I’m hoping I’m past the 1/2” recomended offset between the upper u-joint and lower u-joint and can loosen the nuts some. Monday a lot of questions will be answered. |
